Thread: Shaft thread size
    Shaft thread size
    while replacing the bearings on my Hayward superpump i slightly damage the threads on the rotor, the part the impeller threads onto. does anyone the the thread size so i can put a die on it and clean it up. pump is SP2607X10 2 speed 1hp.
    Thanks
    26,500, DE, IG, Plaster, 1 HP, Hayward Pro Grid 2420 Filter
    22,544
    Re: Shaft thread size
    The shaft on a 56J frame motor should be 7/16"-20, national fine, right hand threaded.
    Hi
    Thanks very much, worked out great.
