Thread: FLO after pumps stop
    Dec 2012
    Manassas Park, VA
    207
    Spa: 1999 Sundance Optima 850
    After the pumps turn off a FLO error is shown immediately. The pumps run again as programmed. Is this normal or an indication that something is bad or going bad?
    Rocco
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Re: FLO after pumps stop
    Is your water level high enough? Have you checked the filter area to make sure there's no debris obstructing flo? If neither applies, it could mean your pressure switch is faulty.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Dec 2012
    Manassas Park, VA
    207
    Thank you for the quick response. A little more informaiton.
    The FLO error would occur each time after approximately 22 minutes of run time, even though the set temp was not reached.
    After removing the filter and checking the lines to make sure they are clear the problem did not go away. So to test the FLO switch i bypassed it by using a jumper. However the hot tub would still turn off after approximately 22 minutes even though it did not reach the set temp. However this time no error message was displayed.
    To provide a little more insite. Last year I had to replace the seal and propeller in the main (Jets 1) pump. However while researching this the propeller I needed for my 2.5 hp pump was replaced by a propeller designed for a 2.0 hp pump. Could this explain the FLO issues even though it takes approximately 22 minutes for the FLO error to occur. It looks like the 2.5 hp propeller is available again as well.
    Propeller bought and installed: 6500-309 - http://www.spaandpoolsource.com/6500-30 ... meter.aspx
    Propeller spec'd for the pump: 6500-295 - http://www.spaandpoolsource.com/6500-29 ... r25hp.aspx
    Hope this all makes sense and helps.
    Manassas Park, VA
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Sorry I can't help much in this case. I only know that in the past, the flo code on startup without heating has meant either a pressure switch, or in the last instance, a pump failure.
    If FLO is only triggering 22 min. After running, I am at a loss, other than to say it must mean for some reason after 22 min flo is reduced enough for it to want to shut down the heat. So perhaps that incorrect part is failing.
    Helpful Links:
    22,548
    If it's happening at 22 mins every time it runs it sounds like a timer is kicking it out. Will it run longer than 22 mins without kicking off?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    ^i wondered about this b/c I know my own jets automatically turnoff after 20 min and my circ pump kicks in every 20 min I think. However, when I am heating, circ stays on until heated. So I assumed Rocco's worked the same way.
    Helpful Links:
