Results 1 to 11 of 11
Thread: Pool motor wiring help
    I need help wiring my above ground pool motor for 110V. I have a new motor BN35v1 which is a 115/230 volt motor. The motor has numbers 1 2 3 4 5 6 where wires can be connected to them. I simply have a black wire and a white wire that I need to know which numbers they should be connected to. I also have the ground wire but I know where it is connected
    Central California-27,000 gallon in ground concrete pool-Pentair Clean and Clear 420 Cartridge Filter-Polaris Pool Sweep
    Re: Pool motor wiring help
    Welcome to TFP!
    There should be a wiring diagram on the motor, usually a small metal plate with the diagram on it, that shows how to make the connections.
    38,521
    Post up a picture of the diagram if you want a second opinion on interrupting it.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Here is a copy of the plate on the motor.
    [attachment=0:19nzumhd]Pool motor Plate.JPG[/attachment:19nzumhd]
    Here is a photo of the back of the motor. I would like to know based on the wiring diagram which number on the back of the motor would I connect the black wire to and which number would I connect the white wire to. This is for 110V connection and I already know where to connect the ground wire.
    Any help would be much appreciated.
    [attachment=0:11irkxcq]Back of motor.JPG[/attachment:11irkxcq]
    38,521
    Hmm. I understand your confusion. Are you able to see any of the colored wires listed in the diagram? Maybe they are behind the plate?
    I cant get to the wires behind as the plate doesn't look like its removable.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    I don't know if this will help or not but here is the thread where I asked for help to attach a power cord to a new pump. It shows pictures of the back of my old pump with wires still attached and the new pump and switch.
    Love TFP? Become a
    TFP Supporter!
    You connect the black and white external power wires to 1 and 6. Either one can connect to 1 and the other to 6.
    However, there should be two other wires coming out of the motor that are supposed to be setup to tell the motor what voltage you are supplying. The internal black wire should be connected to 6, and the internal "black tr" wire should connect to 5. I don't see either of those wires in your photo, which is confusing. It is possible that they have been pushed back between the connection block and the chassis. Without those two internal wires connected correctly I don't think it will work at all.
    Thanks everyone, I will see if I can find some wires pushed back behind or something.
    I encountered the same issue with no jumper wires located on the front of the wiring panel that would be used to change the supply voltage. I ended up opening the motor and discovered that the jumpers are located on the rear of the wiring panel and the motor comes preset for a 230V supply. I changed the jumper wires to 115V based on the wiring diagram on the plate on the motor and it works fine.
    Black TR ==> Moves from 3 to 5
    Black ==> Moves from 5 to 6
    If there's a simpler way to change the supply voltage, I couldn't find it anywhere else online. This solution works, but it's certainly not user friendly.
