Results 1 to 8 of 8
Thread: Refilling hot tub with pool water
    We have a fastlane endless pool that is about 2600 gallons. We also have a 230 gallon hot tub. I am wondering what, if any, problems/concerns there might be if we refill the hot tub with water from the pool and then top off the pool with the garden hose. The main reason for doing this is that the pool is already at 84 deg, so there would only be a short wait for the hot tub to be up and running at 102 deg.
    250 gallons Viking 100 Hot tub
    Sanitize with Bleach
    PH balance with Muriatic acid
    Test with Taylor K-2005
    City Water
    Re: Refilling hot tub with pool water
    Shouldn't be a problem.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Far easier and simpler to do so, it's easier to correct and rebalance the pool water than starting the spa from scratch. This is all I ever do when tree is a pool and spa in the same location
    Stuart Murray
    Scotland UK
    UK NPPOC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    That is unless you are that one guy in the world that uses baquacil in your pool and chlorine/bromine in your tub. Then don't do it
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Jul 2012
    296
    Quote Originally Posted by X-PertPool
    Excellent point!
    Stuart Murray
    Scotland UK
    UK NPPOC
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    is there a easy and fairly fast way to do this? i guess i could try siphon with garden hose but shouldn't there be an inexpensive pump to speed up the process?
    22k gallon, Sand filter (Triton II TR 100)
    IG tile
    Pentair VS pump
    SWG
    Sundance Chelsee spa
    Jul 2012
    296
    http://www.ebay.co.uk/itm/Wolf-400w-Cle ... 3ca75ae144 is the type I got off eBay for less than GBP30 (USD~$40)
    Something like that is ideal.
    Stuart Murray
    Scotland UK
    UK NPPOC
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    perfect! thanks.
    IG tile
    Pentair VS pump
    SWG
