Thread: stenner pump fell apart
    I guess the bottom somehow got all corroded and the bottom of the pump fell off. It had only been in operation for about 4 months or so
    Has anyone else had this happen?
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    22,550
    Re: stenner pump fell apart
    Can you post some pics of it?
    I haven't seen that happen.
    ok so with further inspection, the two clips that hold the bottom on broke so the bottom fell off and the entire inside fell out. I used screws into existing holes to put it all back together and Im looking for new clips because they are more convenient when I need to take it apart to change tubes in the future.
    Aug 2010
    Austin, TX
    200
    What are you using the pump for? How is it mounted?
    If it's for acid, bad bad things happen when you co-locate the pump and the tank.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
