Thread: Easytouch Wireless Controller NO COMM
    I am having a problem with the wireless controller of my Easytouch 8 system giving a NO COMM error. I have tried resetting both the outdoor panel and controller, and have also tried syncing both again by sending the wireless address, but my controller displays "Address Lock" and "searching for signal" but never syncs. This all began after having some power outages two nights ago. I also have the protocol adapter connected to the same terminal screws on the comport, and everything worked fine until we lost power. I have not pulled the panel yet to see if/what lights I have on the transceiver board, nor have I cleared the EEPROM yet. Is it normal for the remote to display address lock as soon as you go to the wireless address menu?
    18x40 AG, Wilbar
    Hayward Perflex 50 gpm
    1 1/2 hp pump
    Re: Easytouch Wireless Controller NO COMM
    After speaking with Pentair tech support yesterday, I pulled the transceiver board and noted the power light was on steady, and the 485 and RF lights flashed occasionally. I pulled the power to it to reboot the board, but still no dice. According to the tech, sounds like it may be a main board issue. I will update again after I get a tech out here to look at it.
    18x40 AG, Wilbar
    1 1/2 hp pump
    May 2014
    North Carolina
    18
    Quote Originally Posted by jgdds View Post
    I know this is an old forum thread, but what was your final solution or fix? I have exactly the same symptoms: power led is lit on the trans board and the 485 and RF leds occasionally flash; Main panel will show "sending" wireless address but remote shows "address lock" and the two never sync up; did all of the things recommended on other threads for powering off and on, battery changes, etc.
    15K, IG, Sunstone Pearl (pebble) finish, Pentair EasyTouch 8 control system, Pentair IntelliFlo VS pump, Pentair IC 40 SWG, Pentair CC200 Cartridge filter, solar heating - 4th time pool owner
    Jul 2015
    New Orleans
    1
    Quote Originally Posted by Semi-retired View Post
    Semi-retired,
    Did you ever fix your system? I too am in exact same situation!
