Results 1 to 9 of 9
Thread: HELP!
    HELP!
    We are new to the pool closing. We need to know in an area that freezes at night only typically, should we close the pool or keep the pump and filter running t all times? We are confused because pool guys have said different things. We have the gizmo in pool skimmer, lowered water below skimmer, and run the pump only when just above freezing. We have a freeze guard on pump that starts pump if temp is below 38. Is this right or should we just fill it back up and let the pool.run through the winter without lowering the water at all.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: HELP!
    If you are going to run the pump then you need to keep the water up to normal levels and maintain the water balance just like during the regular pool season. You don't say if you have a main drain, but if you don't and the skimmer is plugged you will damage the pump by continuing to allow it to run while dry.
    Love TFP? Become a
    TFP Supporter!
    Re: HELP!
    We have a main drain on the bottom of the pool. Thats why pump needs to run. Does that make a difference?
    22,539
    Re: HELP!
    Closing it or keeping it open is a personal preference. If you're not going to cover it and you're going to run the pump anyway, you should just fill it back up and maintain it normally. Unless you blew out the skimmer line, the gizmo isn't doing any good for the line freezing. I don't know where you live so I don't know how deep the frost line is there, so that may not be an issue.
    Re: HELP!
    Oklahoma. Thanks for the help!
    22,539
    Re: HELP!
    In OK your frost line could be deep enough that the skimmer line may freeze if you have a prolonged event.
    Re: HELP!
    So is my setup correct?
    22,539
    Re: HELP!
    I'd raise the level back to normal and remove the gizmo. Unless you cover it and have blown out the skimmer line and valved it off from the main drain.
    Re: HELP!
    Thanks a bunch. You've been a great help !
