Results 1 to 8 of 8
Thread: Cover Inground Pool
    Dec 2010
    Massachusetts
    50
    Cover Inground Pool
    So my cover keeps blowing into my 18*36 inground pool I had the water bags on last year but the freezing did damage to my stamped concrete finish. My guess is the when the water bags freeze they expand and since they are frozen to the concrete surface like a glue is pulls the concrete finish off. Not cool! Any alternative solutions out there? Pressure treated boards all the way around?
    I'd like to get a nice mesh loop loc type of cover one day but they are too expensive for me now. The pool has a spill over hot tub so that would be a custom cover I need which is like $3500.
    Thanks
    Nov 2011
    Moberly,MO
    1,010
    Re: Cover Inground Pool
    The water bags most likely aren't the cause of the deterioration of the deck. The most likely culprit is the trapping of moisture between the cover and the concrete with freeze and thaw. About the only other way to cover it is a loop-loc style cover.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Dec 2010
    Massachusetts
    50
    Do you think some foam like this between the cover and concrete would solve my problem?
    http://www.lowes.com/pd_377085-14510-75 ... facetInfo=
    Nov 2011
    Moberly,MO
    1,010
    There isn't anything that I know of that will stop this fromhappening. What is causing this is the change in temperatures on a day to day basis. It allows condensation to form and it soaks into the concrete then when temperatures drop the moisture freezes and swells causing the concrete to chip.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    What about sealing the deck with something like Thompson water sealant? This would help prevent water from penetrating into the decking which in theory help prevent the cracking from expansion.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Dec 2010
    Massachusetts
    50
    I do seal it every year with a nice acrylic one. I'm convinced that as the water bag freezes it pulls up on the tarp which is frozen to the concrete. Water expands as it freezes. I'm hoping the foam will provide enough flexibility to offset that effect.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    You can use 5 gallon buckets full of water, this might have less of a footprint compared to a water bag. You can usually score a bunch free buckets from places like ice cream parlors etc. that get ingredients in 5 gallon buckets.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Dec 2010
    Massachusetts
    50
    I decided to leave it off this year. We'll see how that treats me. It looks better. Any concern with no cover?
