Results 1 to 11 of 11
Thread: Upgrading power panel
    Sep 2012
    Dunedin, FL
    33
    Here is my rusting power panel:
    Id like to replace with a newer intermatic model with digital module.
    What do I do with the pool light (uses the 300w transformer ), the new boxes dont include transformers. Do I replace with a new 120v pool light or, add an external 300w transformer? Thanks.
    ~10,200gal IG kidney plaster pool w/overflow spa
    AquaRite SWG
    Hayward Star-Clear 120cartridge, Hayward 1hp SuperpumpII
    Solar panels.
    22,553
    Re: Upgrading power panel
    I'd move the transformer to the new panel or mount it in an external enclosure mounted to the new panel.
    Sep 2012
    Dunedin, FL
    33
    Thanks, thats's what I was thinking but, just curious if anybody has converted to 120v bulbs...if that is even possible?
    Is it just low voltage is safer or, do new pools use 120v?
    AquaRite SWG
    Solar panels.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Low voltage is definitely safer. We just had a couple of people in this area die swimming around boat docks that had stray voltage from the dock electrical systems. This was on 2 different lakes.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    22,553
    Also your niches might no be rated for the higher voltage lamps so they'd have to be changed if they're not.
    Sep 2012
    Dunedin, FL
    33
    ok, thanks. Looking at options for next years upgrades.
    AquaRite SWG
    Solar panels.
    May 2011
    Orange County, CA
    696
    I'd suggest keeping the 12V lighting as it is much safer. The suggestion of moving the existing transformer into the new panel is reasonable, but must be done with extreme care. The code compliant transformers for pool luminaires have special protection to prevent contact between the high and low voltage terminals. The protection afforded by using 12V for the lighting fixtures is completely compromised if that protection is removed. In Intermatic 12V transformers for pools, there is a grounded metal shield between the high and low voltage terminal strips to minimize the potential for passage of high voltage along the low voltage wires. However, removing the transformer itself from the metal box supplied, and then placing this directly in the new panel would eliminate this grounded shield. What does the transformer that you are currently using look like? Also, is the circuit GFCI protected?
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Sep 2012
    Dunedin, FL
    33
    http://www.intermatic.com/~/media/In...%20Series.ashx
    I could just replace the panel and add a new digital timer model. My original idea was to replace the panel with smaller digital and then add a separate transformer .
    Digital modules have 3 circuits so I could have the pump, solar and salt (if I add in the future) on timers.
    AquaRite SWG
    Solar panels.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Do you really mean replace what you have with a fully automated system?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Sep 2012
    Dunedin, FL
    33
    I should have said electronic timer, like the intermatic P1353ME module. It would handle my simple water needs w/o the costs of of a full blown controller.
    AquaRite SWG
    Solar panels.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    You could upgrade your panel to a full automation system and add electronic control valves for your spa. That way when you want to use your spa you could just do it by the touch of a button and not have to make any manual changes to the valves.
    Paul
