Results 1 to 13 of 13
Thread: adding new deck by the pool
    Feb 2011
    Petaluma, Ca
    665
    Putting in a new stamped concrete deck for the barbecue, fire pit and more seating area. I'm in the process of getting the utilites plumbed where the slab will be. I'm running a 2" gas line under that will be connected to the house at a later date, this will allow the addition of a pool heater if I choose. The line will also "T" off and supply the barbecue and fire pit. This is the area approx 1 year ago.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Feb 2011
    Petaluma, Ca
    665
    Re: adding new deck by the pool
    I dug most of the dirt out with the tractor to get a somewhat level pad then dug the trenches for the electrical / gas with a shovel.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looking good so far! Looks like a lot of shovel work. Make sure you run extra water and conduit to anywhere you could conceivably want it! PVC is cheap.
    Feb 2011
    Petaluma, Ca
    665
    Yea, that's what I didn't do when the main deck was poured, this time I have extra's installed.
    Feb 2011
    Petaluma, Ca
    665
    The gas wont be installed until January 2nd +- so things will slow for a while, really wanted to just get the ground leveled and compacting now. Expect to be ready to pour by 2-1-13 approx depending on the weather.
    Feb 2011
    Petaluma, Ca
    665
    Gas will go in tomorrow. here's what it looks like now. Not very impressive at this point. Also here is a pic of some speaker covers we made to prevent them from being stolen / messed with since the pool is approx 150' from the house and we live on a country road.
    Feb 2011
    Petaluma, Ca
    665
    Gas lines in, Waiting on the pressure test to fill in the trenches, hopefully Saturday. once the forms for the deck are in place they will make the stubbed out lines through the deck the correct length and reduce them to 3/4". I guess that is enough for a fire-pit or barbecue.
    Feb 2011
    Petaluma, Ca
    665
    Here is an update, patio poured, retaining wall done.
    Feb 2011
    Petaluma, Ca
    665
    The retaining wall with the stucco half done. I need to get some pics of the finished wall. Side note: Pool got to 68 deg today.
    May 2011
    Orange County, CA
    696
    Quote Originally Posted by bobby1017
    Did you install the gas PE lines yourself? When I had to replace our line, I thought about doing it myself, but couldn't find needed materials for this. I ended up having some plumbers do it, and they used a long coil of 1 1/2" PE for the 125' run to the pool equipment pad. They used a plate welder to weld the PE pipe fittings and risers to the PE itself. Did you add a tracer wire?
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Feb 2011
    Petaluma, Ca
    665
    The lines under the deck are 2" steel gas pipe that has the yellow plastic coating, you then wrap any of the fittings with this special 10 mil tape so they are protected also.
    The main supply from the house will be the plastic line you are talking about so there will need to be a tracer wire attached to it. There will only be two fittings required, one being the riser by the gas meter, the other a coupling that will attach to the 2" steel gas pipe. from what the supplier told me these are "friction" fitting that all you do is push them on to the end of the plastic and some kind of O-ring will seal it. Seems strange to me but I guess since the pressure is so low it works. The fittings are made of steel. The material to run 170' of the 2" plastic are approx $450.00, digging the ditch 18" deep min will be the hard part, at least we have fairly soft earth.
    Feb 2011
    Petaluma, Ca
    665
    Things are slowly coming together, got the barbeque moved to the patio this saturday, I was able to make some fork extensions that will clip to the bucket of my tractor. Using a front loader as a forklift is harder than you might think as the hydraulics don't work as smooth as a forklift's would, plus driving down a dirt road is a lot rougher than it looks, when I got to the deck it was "leaning" supported by a couple ropes I had tied to the bucket, they were 3/4" nylon and they were stretched tight. Fortunately I was able to get some blocks under it and it rocked back to level as I released the ropes. After that 4 people were able to do the final positioning. I'll get some pics here shortly. Next up is the nat gas line.
    Feb 2011
    Petaluma, Ca
    665
    Here are a couple pic's of the new patio. All the brown river rock was a free-be on craigslist, I had all that in the back of my p/u, I think it was a bit overloaded.
