Results 1 to 8 of 8
Thread: Additional tests needed for spa?
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    I have just added a spa to the backyard and already use the Taylor K-2006 for my pool. What additional test kit stuff will I need to test chemicals (bromine?) in the spa (Sundance 780 series Chelsee model). They gave me strips but don't think I want to use 'em.
    Thanks, Ben.
    22k gallon, Sand filter (Triton II TR 100)
    IG tile
    Pentair VS pump
    SWG
    Sundance Chelsee spa
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Additional tests needed for spa?
    I started off with bromine. After about a month I switched to bleach. To be honest I fill the tub with fresh water and add baking soda and calcium chloride and then just bleach when needed. Sometimes I add muriatic acid as the pH tends to drift upwards.
    Your kit for your pool is more than adequate for your tub. You need nothing else.
    (the strips are okay for getting a quick and rough idea of what the chemistry is)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    San Rafael, CA USA
    12,082
    I'd suggest starting out with Dichlor for about a week to build up some CYA in the water before you switch to using bleach.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Unsure about drop kits, but with comparators and (basic) photometers (ie DPD reagents) you can test the bromine residual using the chlorine DPD reagents and multiplying the result by 2.25 for a bromine residual, hopefully someone with knowledge of Taylor Tests can confirm or decline if it works the same way.
    If that is the case, you wouldn't need any extra test equipment whatsoever, as for the test strips either throw them away, or take tests with them after using your Taylor and laugh at how horrendously incorrect the results are.
    Edit > if you do decide to change to chlorine (bleach) you have a ready to use, balanced and disinfected supply in your pool that can be used to fill the spa with, it saves balancing two pools of water
    Stuart Murray
    Scotland UK
    UK NPPOC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by chem geek
    forgot to mention I did add cyanuric acid. I purchased 4lb container I believe. I calculated how much i needed based on gallons of the spa and then measured out how much i needed in grams on a food scale. In other words I just treat it like a tiny pool that needs to be drained every 3 months. A digital food scale does help out a lot with a spa since it doesn't take much to throw the levels off wildly unlike a pool that you can usually work your way up to the desired level.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    Ok, thanks for all the replies. I guess I was under the impression that the hot water demanded something above and beyond bleach. Hence the bromine. To confirm...you guys are saying bromine is not required and there are no drawbacks?
    IG tile
    Pentair VS pump
    SWG
    surfhawaii's Avatar
    May 2011
    Kailua, Hawaii
    63
    The suggestion: 'Edit > if you do decide to change to chlorine (bleach) you have a ready to use, balanced and disinfected supply in your pool that can be used to fill the spa with, it saves balancing two pools of water' is great idea! you guys are great.
    IG tile
    Pentair VS pump
    SWG
    Jul 2012
    296
    Quote Originally Posted by surfhawaii
    Correct, bromine is slightly less work, but for the home user, chlorine is fine providing you keep it in check.
    Stuart Murray
    Scotland UK
    UK NPPOC
