Results 1 to 10 of 10
Thread: Borates and Exzema
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Borates and Exzema
    Hi all,
    This past summer was my first season with borates. One of the things I noticed was that my 4-year old daughters exzema practically totally cleared up. When the season was over in September, the dry itchy scaly skin returned. We took her out of fall swimming lessons at the local pool because the water is terrible for her skin. So I figured perhaps I would try adding borates to her bath water. And yes, it works. It softens her skin and takes away the itching. So I am wondering if there are any negative effects to this. Obviously I can't gauge the parts per million. I just sprinkle some in and turn on the jets. Can this be harmful to my daughter. Thanks in advance for any info you may offer.
    GC
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    22,553
    Re: Borates and Exzema
    If they get high enough and she stays in the water long enough it could expose her to above recommended levels. However you CAN use the Pool Calc to figure how much to add to the tub. In 30 gals of water ~2 oz of borax will raise the borates to about 50 ppm.
    Mar 2007
    San Rafael, CA USA
    12,082
    This paper shows that there is some benefit from boric acid, mostly in preventing itching, and that Shuangfujin (SFJ) was the most effective.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by chem geek
    What is SFJ?
    Sent via Tapatalk...
    Mar 2007
    San Rafael, CA USA
    12,082
    SFJ is the abbreviation for Shuangfujin which is a Chinese herbal medicine.
    Jun 2012
    Mint Hill, NC
    2,589
    Any idea what it is? I thought I read that it was at least partly a bacteria?
    Mar 2007
    San Rafael, CA USA
    12,082
    According to this link, Shuang-Fu-Jin is a combination of herbs: portulacae, radix sanguisorbae, radix sophorae flavescentis and cortex phellodendri (see also this link) with the first three apparently being the most active anti-inflammatory ingredients. As far as I can tell, it does not contain bacteria.
    Jun 2012
    Mint Hill, NC
    2,589
    Thanks... I am too worn out to look for the reference I saw but I would guess I misread it or it was misleading.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    GreatCanadian, I'm glad it's effective for her. Boric acid is a component of bath bombs, just so you know, so if you use a little moderation, I'm certain you'll be fine.
    And thanks again for the great science, ChemGeek, I'll go take a read!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jul 2011
    844
    Thanks guys and gals for the input. You've put my mind at ease. I will read that paper Chem Geek. Merry Christmas everyone. Or Happy Holidays. Whichever you prefer!!
    Bestway SWG
