Results 1 to 11 of 11
Thread: Any disadvantages to using dry acid?
    After a few bad experiences at my pool store, I am now purchasing my chemicals from Home Depot. It's close and they have everything I need, except for one thing: muriatic acid. However, they do have dry acid, which should work just fine. Now, just to make sure, I was wondering if there are any bad side effects to dry acid? I know chlorine in powder form messes with the CYA levels, so before using acid in powder form, I wanted to verify it is ok to use:
    Active ingredient is sodium bisulfate (93.2%). What do you think? Safe for regular use?
    Thanks so much!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Any disadvantages to using dry acid?
    Check the stone/concrete section not pool section, they should have the acid there if they carry it.
    The dry acid adds some sulfur but I don't recall what form it takes over time.
    Sent via Tapatalk...
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Not sure where you're at but in Florida HD sells MA in 2 Gal pack in the garden center.
    I am actually located in southern CA. I will try the dry acid but will check the stone/concrete section for MA. The pool section is indeed in the garden center; I could only find the 2 gallon liquid chlorine pack but no MA.
    Mar 2007
    San Rafael, CA USA
    12,082
    Dry acid will build up sulfates which at higher levels can be damaging to plaster/concrete surfaces (see Sulfates - what's the problem? and Sulfates why so bad?).
    Oct 2012
    209
    Dry acid is more expensive than muriatic. We get our acid from a plumbing supply store (at a very cheap price).
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Also, check the paint section, sometimes they have it there.
    Don
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Cept for large local authority pools, it's all I ever use for acid, and cannot report any problems with it. I have known about the sulphate increase, but in my experience it is negligible, Muriatic Acid is certainly cheaper and more effective, but that can be balanced with the easier storage and handling of Sodium Bi-sulphate.
    Stuart Murray
    Scotland UK
    UK NPPOC
    Mar 2007
    San Rafael, CA USA
    12,082
    At the maximum limit of 300 ppm given by one of the references, you'd need to cumulatively add around 31 pounds (around 2.6 gallons) of dry acid per 10,000 gallons (equivalent to around 2.9 gallons of full-strength Muriatic Acid which is 31.45% Hydrochloric Acid) with no water dilution.
    Melbourne, Australia
    74
    Not all chlorine in powder form changes CYA levels.
    I don't believe calcium hypochlorite changes CYA levels.
    13,000 gallon; sand filter; inground; fibreglass; pump not sure yet (need to check); Installed over 12 months ago.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by juzzie
    Correct - however it does raise Calcium Hardness levels which can eventually lead to scaling.
