Thread: can't blow out skimmers
    Apr 2010
    Central NJ
    227
    I have a new compressor http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051. I've set it up to 30psi and it's not blowing out my skimmers. They keep gurgling so I know there's water in there. What can I do other than getting a vac?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    4knights's Avatar
    NE Kansas
    419
    Re: can't blow out skimmers
    Have you tried blowing the other direction? Either from the skimmer to the pump or from pump to skimmer? When I blew my lines it was difficult from the skimmer toward the pump but simple from the pump to skimmer. Not sure why it was easier one way but, any water still in there was mixed in with the gallons of pool antifreeze after I got it blown out. .
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Apr 2010
    Central NJ
    227
    I connected my compressor thru the drain plug in the pump gasket. How would I hook up a compressor through the skimmer side?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I can't imagine a compressor pushes enough volume to clear a skimmer line. I disconnect the pump union and use a shop vac to blow the line. I have Old Faithful 6ft high until the line is empty.
    4knights's Avatar
    NE Kansas
    419
    Just as JohnT said, I use my shop vac. I bought a 2inch rubber hollow center plug from the big box store, it slid right onto the shop vac nozzle. Stick the nozzle down into the skimmer pipe(basket removed) turn on. When I did it the other way and pushed water from the pump union it did just like John said- old faithful coming out of the skimmer.
