Thread: Calcium Hardness Treatment
    May 2012
    Brevard Co., FL
    29
    I was just curious if anyone has rigged a system to reduce the calcium in the pool water similar to a whole house water softener system.
    12000 GAL Total Pool & Spa-1000 GAL Spa/IG/Exposed aggregate/Cartridge CC200/Pentair VS-3050 (174 GPM max.)/SWG-Pentair Intellichlor IC-40/Pentair EasyTouch4/ "The Pool Cleaner"/Screened Enclosure/ Taylor K-2006C Test Kit.
    22,550
    Re: Calcium Hardness Treatment
    There are some commercial units but none available in your area. Typical house R/O units are not a good choice for removing CH from pools as the waste stream is quite a large portion of total flow. In most areas of the country it's less expensive to drain and replace the water.
    38,292
    There are some members that redirect all the house roof rain run-off into the pool. They partially drain the pool before storms and then refill with the rain water to lower the CH of the pool.
    Not exactly what you are asking, but one method to lower the CH.
