Results 1 to 7 of 7
Thread: needing help....... from australia
    hi all....i'm ruth and live in australia......and i am hoping someone over there can give me a clue about pool maintenance. it looks like you have a different approach to chemicals and care of pools compared to the mainstream view, which interests me. my problem is that we have a new place and it has a ruddy large pool..20 metres by 7 average depth of 1.5...would not be my choice but this is what we have!
    i figure it holds roughly 250,000 litres. it was green like the swamp from calcutta. last week i added big amounts of chlorine and a week later(today) vacuumed out heaps of sludge....it is finally clearing up! the little robot is scooting around doing it's thing. now here is the question.....what next?
    i would love it if i could be given some sort of plan for care. just realised probably no-one is looking at this site as you are approaching winter unlike us....but maybe some are looking for info to winterise their pools. fingers crossed!
    hope someone can help.
    all the best and merry christmas as well
    ruth
    Butterfly's Avatar
    South Carolina
    10,045
    Re: needing help....... from australia
    Welcome to the forum
    We're here, even in our winter!
    Best place to start learning our method is Pool School, big white button at top right of each page.
    Post a full set of test results and we can give more specific direction.
    We're glad to have you with us
    You're done SLAMing when:
    38,397
    Welcome to TFP!!!
    As stated above, I would start by reading all the Pool School articles and asking questions about anything that does not make sense to you.
    Quickly you should come to realize that having a GOOD test kit is the key to understanding and maintaining your pool. We recommend the TF100, which is luckily available from TDchlorinators down there.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    +1 for pool school and test kit.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    of course....the one here expired 2007...i will get one tomorrow!
    with thanks
    ruth
    38,397
    Just want to make sure you are planning to order the kit. Here the recommended test kits are not available locally.
    The key is the FAS-DPD chlorine test so watch for that.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    Hi Ruth. Just want to say Hi from across the ditch. I got a home a few months back and never looked after a pool before. As mentioned above order a test kit, and read and reread the pool school. Follow the advice and you'll have a crystal clear pool that is easy to maintain.
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
