Thread: Anyone have problems with Composite Decking like Trex?
    This winter I want to refinish my 20+ yr old wood deck. Its 16x16'. My plan is to demo the top, repair and reuse as much of the original underpinning, and then screen it.
    I plan to avoid building a real roof and using overlapping shade canopies. 1 extra option is an outdoor hearth wood burning fireplace. Currently composite is 3 times more pricey, but I'd love to not have to worry about stain, splinters, knots etc. Doing some research I've found some folks really against it, showing failures and fading. Ive found a cheaper brand, choicedeck at lowes which is $35 a 1 1/4x6x16' which looks good.
    Any failures out there?
    Any major fading?
    Would you do composite decking again?
    When the only tool you have is a hammer everything starts looking like a nail.
    Doughboy 16x24 "Aboveground Inground" in progress...
    rdw1961's Avatar
    May 2012
    Mount Pleasant, PA
    17
    Re: Anyone have problems with Composite Decking like Trex?
    We have two composite decks. The deck on our house is 11 years old, cedar color, uncovered, with full afternoon sun. Other than power washing it every spring, it looks as good as the day it was built. Our pool deck is 5 years old and the color is more of an egg shell to match our AGP. Again, other than a spring power washing, it has not required any maintenance. It too still looks brand new. I believe the savings in time and energy on the maintenance far outweighs the initial cost of composite.
    24' Above Ground Round vinyl
    DE Filter pump 1HP
    Flow Rate 39GPM
    14700 gallon
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Our Trex has faded some, but it still looks good. No staining, no splinters. I'd never use treated pine again. Dark colors tend to fade more and get hot in direct sun.
    4knights's Avatar
    NE Kansas
    419
    I'm doing the same remodel job on a second story deck and have to add stringers for support due to the weight of the composite boards. My neighbors composite "trex" deck has no fading after 5 years but man it's too hot to stand on in barefeet during the summer. The color is a brownish, so kind of worried about the same heat issues when I do mine.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Good to hear good experiences. The vague info I saw seemed a bit sketchy, and I think people with failures might have had improper installation techniques. What I didn't like seeing today at the depot was huge stack of trex all of which were wavy. I'm thinking the half point of not wood is so I don't need to look down boards and pick the straight ones!
