Thread: Band separated on tall filters
    Aug 2011
    Fort Worth, TX
    32
    Howdy all... I have one of those tall Pentair DE filter systems. It has 4 tall accordion type filters inside. While cleaning those today, I noticed the little white band (think there are 3-4 on each filter) was separating. It appears each one has come apart, actually.
    Just wondering if it's time to get new ones or not. Maybe it's not an issue either though... Or is there another white band I need to adhere to it... I don't know. The system is only a year old now. Wasn't positive if those last any longer or what.
    Any input is greatly appreciated!!! Thanks in advance.
    23x34' IG freeform play pool (18,850 gallon) ~ 7' spa raised 18" with 6 jets and 5 tier waterfall ~ IntelliChlor SCG ~ Pentair Intelligent VS-3050 variable speed pump ~ Clean and Clear 420 cartridge filter ~ Easy touch controller ~ Blue Granite Pebble Sheen ~ Intellibrite LEDs ~ Turbo twister slide ~ 8x8 flagstone tanning ledge with umbrella sleeve and bubbler ~ In-pool flagstone table with umbrella sleeve ~ 947 sq ft exposed aggregate decking
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Band separated on tall filters
    The bands aren't really necessary. I have been operating without the bands for several years now. You just need to make sure there are no holes in the filters where debris can make it past.
    Mark
    Aug 2011
    Fort Worth, TX
    32
    I appreciate it Mark!
