Thread: Green water fountain
    Hi everyone,
    I'm helping out my brother-in-law with a fountain he has inherited in his new home. (8'x5'x 1 ft Deep).
    They just moved in, and it's been neglected for months, so needless to say it is green pea soup.
    I calculated that it has 300 gallons.
    Told him to add 1 cup of bleach in the am and two in the pm - which he has since last Saturday. ( calculated that it would bring the FC up to 15 or so). Also told him to brush it as often as he can. Got a chlor tab feeder for him and filled it with chlor tabs.
    I couldn't see the very bottom last weekend, but the sides exposed are 1 " mosaic tiles.
    From what I can tell, there is no filter system, so he's had the pump shut off.
    So far, it's still green, so maybe I don't know what I'm doing, even though I told him it would be cleared up in a week. (I have a pool, and have used troublefreepools and poolsolutions to keep it perfect for several years now).
    Any suggestions would be great. More bleach? Just drain and refill and get it over with??
    Thanks in advanced.
    Travis
    20,000 Gallon In-ground Vinyl Liner
    Hayward Sand Filter
    CompuPool CPSC48 SWG
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Green water fountain
    Drain, wash with bleach, refill seems cheap and fast. 15ppm with unknown CYA seems like it has the potential to be a problem.
    Sent via Tapatalk...
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Good idea UWV.
    OP, not to mention that there's no filtration system, so you'll never get the dead algae completely out of there.
    I would shock it after you refill it, while running the pump for 24hrs. Just to clear out the lines.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
