Results 1 to 14 of 14
Thread: Installing SWG tomorrow, can I put the salt in today?
    May 2012
    Austin, TX
    140
    I am having SWG installed tomorrow...but I have time to install the salt and stabilizer today.
    Is it ok if do that now?
    David
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    Jul 2012
    Blountsville, AL
    59
    Re: Installing SWG tomorrow, can I put the salt in today?
    Yes. Needs a little time to dissolve anyway.
    20' x 38' x 40' Lagoon, 38K Gal, Vinyl, Aqua Plus control, SuperFlow 2 hp pump, 3.7 sqft sand filter, T-15 SWG
    2 ColorLogic 4.0 LED lights, Polaris 280, TF-100 test kit, Finished in September 2012
    Master Spas Twilight 8.2
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Sure go for it. Did you compute how many bags you'll need? You can use solar salt instead of "pool salt". Pool salt is finer ground. Remember your pool isn't at 0 for salt. So you may want to add a couple bags less. It's easier to add than to remove.
    When I added my 12 bags, (do a couple of trips if you don't have a truck (don't overload your vehicle)), I added 9 or 10. Then brushed my sides down, it mostly dissolved in 1 hour or so. If you have your pump on aim a jet to the pile to help it dissolve. Dissolve time will also depend on water temp. So don't be too concerned. It will dissolve with time.
    Good luck with your unit. It make pool care easier.
    May 2012
    Austin, TX
    140
    Thanks for the answers - I am super looking forward to the SWG. No more lugging jugs!!
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Just like bobo said....go light then add more if needed.
    Did you end up going with the Hawyard Aquarite 40K?
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    4knights's Avatar
    NE Kansas
    419
    My pentair SWCG manual says to wait 24-48 hours after salt has been circulating before turning it on, it's supposed to reduce possibility of surge in the cell from undissolved salt.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    May 2012
    Austin, TX
    140
    OK, so the SWG is installed. It is the Compupool CPSC48, brand new and guess what? It has A LEAK. The o-ring seal where the salt cell gets screwed in is leaking. It is just a drip, not a gusher, and it is working, but kind of a bummer. I called Compupool and they emailed me a warranty form. Annoying that I have to fill out these forms and switch out the part, but let's hope the unit will be RELIABLE after they send me a replacement part. Anyway, I should have gotten the SWG sooner. So done with chlorine. The funny thing is, the money I saved buying bleach was wiped out by the cost of all the clothes ruined by bleach splash.
    Let's hope we can get this baby WORKING
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Quote Originally Posted by Drockfresh
    No you aren't .....you are just making your own now.
    Is it leaking on the inlet or outlet barrel union? Sure you just don't have a pinched o-ring or a burr on the plastic?
    Apr 2011
    Murrieta, CA
    2,360
    I've got the same unit. It's a good unit overall. Are you running it 230 or 115 volts? You'll still occasionally use liquid chlorine (heavy bather load, shocking, any time you need to get your level up quickly).
    You may want to use some o-ring lube and re-tighten.
    May 2012
    Austin, TX
    140
    It's the inlet. The o-ring is not sealing. It is very tight, I don't want to crack the plastic.
    The cell was not screwed into the casing when the unit arrived. Did yours arrive screwed in?
    I purchased it online and suspected something funky when I opened the box.
    It's running at 230 - same as my pump.
    Anyhow, I will get a replacement casing from the company. That will hopefully fix it.
    Apr 2011
    Murrieta, CA
    2,360
    I don't remember, but I believe the casting was pretty tight screwing into them into the fittings.
    May 2012
    Austin, TX
    140
    CompuPool sent me a new enclosure (they also sent a few different sized O-rings). Installed and the leak is gone.
    Apr 2011
    Murrieta, CA
    2,360
    Great news! Glad it's working for you.
    Aug 2010
    Dallas, TX
    4,052
    The day I added my salt.
