Thread: Newbie tip
    gsheltonlhc's Avatar
    Nov 2012
    Lake Havasu City, AZ
    15
    Newbie tip
    When draining your pool it's a good idea to turn off your auto fill valve water source. It sure drains quicker once you do!
    17,000 gal. inground gunite 30'X15' w/7'X7' Spa. FNSPlus 60 DE, 2.0 HP WhisperFlo, MiniMax 400 heater. No SWG.
    19 year old pool but new to me 10/2012. Taylor K-2006 test kit.
    Oct 2012
    91
    Re: Newbie tip
    LOL! Let me add another newbie tip:
    When starting your pump, it's important that the cover be on the skimmer or it will draw air and you'll lose your prime. I chased around for an hour one day trying to figure out why my system, which had worked perfectly for weeks, was no longer able to establish suction. Put the cover back on the skimmer and voila!
    14,500 gallons, Clean and Clear 150 cartridge, IG, gunite, USQ 1152 1.5 hp motor (3450 rpm), Pentair Pinnacle Pump
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Newbie tip
    Quote Originally Posted by SebringDon
    I haven't experienced this when my skimmer cover is off.
    Sent via Tapatalk...
    Oct 2012
    91
    Re: Newbie tip
    Quote Originally Posted by UnderWaterVanya
    Maybe it's something specific to my configuration then, but I can replicate it. Maybe it's because the weir's a little stiff but with the cover on there's enough suction to pull it down where it should be and the flow gets started. Once it's flowing I can take the cover off and it still works fine. Drove me nuts until I figured it out.
    Guess it's time to inspect and lube the weir.
    22,553
    Re: Newbie tip
    Is there a basket in the skimmer?
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Newbie tip
    Maybe we should start with what do you mean by a cover? Do you mean the top cover that keeps debris from falling into the skimmer? That's what I mean.
