Thread: New Pool...How much to start up
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    I have a new 24ft round pool with 50 inches of water=4.1 ft... Aproximately 14,000 gallons
    I am unsure of what to do as far as opening up a new pool...Right now in Northwest Indian we have been having weather in the upper 50s to upper 60s...This weekend 70s and next week 60s and 70s...
    I would like to use the BBB method...but what levels should I work toward getting the pool to and the maintaining...Do I need to shock now...should I shock now and then maintain, or wait until the weather and water warm up...
    I just got electric on Wednesday and have just started running filter and skimmer. What is the best way to go from here?
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Mar 2007
    Morris, IL
    477
    If this is a new pool, you will probably need to get some stabilizer, CYA, in there so that you can actually keep chlorine in there. If you have no algae, then I don't see why you would need to shock, just maintain whatever level of chlorine you need according to how much CYA you have.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Cubby and congrats on your new pool
    I suggest you balance your water now. You can start by reading the following two stickies:
    The ABC's of Pool Water Chemistry by duraleigh,
    http://www.troublefreepool.com/sticky.php?s=4953 and
    "BBB" or "What are all these pool chemicals?" by Waterbear
    http://www.troublefreepool.com/sticky.php?s=94
    Also, have your fill water tested. That way you will always know what you are starting with and what you will be adding!
    A good test kit is the BEST investment we made in our pool. The TF Test kit sold here by duraleigh is the best kit for the money, IMHO. Link in my sig.
    Also, list all your pool and equipment info in your sig. This is needed for those trying to answer any questions you may have.
    If you have questions after reading the stickies, post back and someone will help you! Happy swimming.....
    You're done SLAMing when:
