Results 1 to 7 of 7
Thread: Looking for a cartridge filter replacement....help!
    mrmiguelrobles's Avatar
    Oct 2012
    Puerto Rico
    20
    Hi, guys as I previously posted on : http://www.troublefreepool.com/i-nee...er-t54535.html I've given up on my quest to clean my filter to like new condition.Although I had received some suggestions on where to get a new one, the issues is that I don't know which one I should get. I've used the Pleatco filter finder by measurement (25.5" long x 7" Circ.) that shows several results for several brands. My actual filter has no markings or numbers what so ever, being made in China I thought this pump/filter combo must be a knockoff of some known brand. I've included some pics to see if you can chip in some info. Thanks!
    Peanut Shape Fiberglass, Varies 10-14' X 25' long. 3.5' Shallow- 5.5' deep end, about 7000 gals.
    Splapool 1 HP - 75Gpm Pump and 100Sqf Cartridge Filter.
    Re: Looking for a cartridge filter replacement....help!
    Try this web site. They can lookup replacement filters by dimensions as well as part number or filter model number.
    Oct 2012
    Puerto Rico
    20
    That's the site I've tried before but not sure what's the difference between the results, besides the ones not completly open on the bottom and top.
    http://www.pleatco.com/productsearch/0/7_25-1-2/0.html
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Is there a part number on the end cap of your old cartridge? That's another option to look up the correct filter.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Post a picture of the top and bottom of the cartridge also. The end cap pictures on that website show differences. You have to enlarge to see them however.
    Looking closely at this it appears to me that there are only a few differences - these fit several filters. There are two level end caps and three level end caps, and there are end caps without anything other than a hole and those with a "spider" looking device in the hole. If I looked at it right the two level has a spider in all offered choices, and the three level comes with or without the spider. That means there are three options total really - unless there are some subtle differences I'm missing and this matches the model numbers. So you really only need to concentrate on three comparisons:
    PA100N
    (-M is antimicrobial, -4 is a four pack, -PAK4 looks like another 4 pack) aka Hayward CX870-XRE, Unicel C-7487, Filbur FC-1270
    PA106
    (-M is antimicrobial, -4 is a four pack, -PAK4 looks like another 4 pack) aka Hayward CX880-XRE , Unicel C-7488, Filbur FC-1226
    PA112
    (-M is antimicrobial, -4 is a four pack) aka Hayward CX-875RE, Unicel 7489, Filbur FC-1275
    PPF-105 (seems identical to above)
    aka Hayward CX-875RE, Unicel C-7489, Filbur FC1275 (Same as PA112?)
    Oct 2012
    Puerto Rico
    20
    I will post pictures of top and bottom (both the same) later. Which brand is better Pleatco, Unicel , Filbur?..
    Jun 2012
    Mint Hill, NC
    2,589
    If the end plate matches I wouldn't worry too much - the claim is that Unicel is as good or better than the OEM. The real differences between the PA100, PA106, PA112 appear to be the number of pleats and the molded end style. If the molded end style matches then I'd go for it.
