Results 1 to 7 of 7
Thread: Water pooling on solid winter cover
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    My winter cover (Performance Brand?) has drain holes but leaves and water have pooled to either side of the drain panel which runs the length if the cover. How do I fix it so the drain panel is the lowest point.
    Sent via Tapatalk...
    Re: Water pooling on solid winter cover
    Try loosening the center long strap and all of the width straps to allow the center line to hang lower.
    Support the site
    Jun 2012
    Mint Hill, NC
    2,589
    Thanks. This is the first year we have had a pool.
    Since the fabric is stretched, it is likely that there will continue to be some puddles that won't drain completely. An automatic cover pump might help. The bottom picture has a spot that looks like it might be a hole. Any rips or holes make the cover less safe as they provide a starting place for larger holes or rips. Some sort of weight might help lower the center.
    Support the site
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The cover doesn't look tight enough to me. You may want to verify your spring lengths as it may have stretched some since installation.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by JamesW
    The only holes are a double row along the center line that are designed to drain the cover.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by JohnT
    I will try to post pics of the springs later. I think they are pretty tight. There was no sash until water and leaves sat on the cover. Father in law did not know any better.
