Results 1 to 9 of 9
Thread: Pictures of SWG setups
    Jul 2012
    New Mexico
    66
    If anyone could post up pictures or diagrams of how your SWG's are plumbed in, I would appreciate it. Links to other threads or websites if you know of any good ones. I am thinking of putting one in this spring. My equipment picture if you have any suggestions:
    J.
    In New Mexico 20'x36'/3.5' to 8.5'/32,000 gallon/IG gunite/plaster
    Pentair WFE-4 pump/Pentair CC420 cartridge filter/Raypak 266A heater
    2 Pentair Intellibrite LED's/6 Aqua arches
    Coverpools cover with hidden lid
    1,500 sq ft stamped concrete deck
    Polaris robot
    TF100
    22,553
    Re: Pictures of SWG setups
    Can you list what all those returns are?
    That vertical piece coming out of the heater looks like a good place.
    Jul 2012
    New Mexico
    66
    The six smaller returns are valves for six aqua arches. They can be on or off by turning the valve on the main return. Right out of the filter is a valve for the waste line. Intake side is main drains, skimmer, robot port.
    J.
    Polaris robot
    TF100
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You may have to do a little "re-plumbing" I would install it between the valve actuator and the bottom of the vertical pipe coming out of the heater. Not all SWCG's want you to mount their cells vertically.
    Factory Warranty Station for:
    Jul 2012
    New Mexico
    66
    Thank you for the input. I am not afraid of a little pvc moving and adjusting. I figured it needed to be after the heater on the way back into the pool.
    J.
    Polaris robot
    TF100
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Here's mine-
    Jul 2012
    New Mexico
    66
    Any concerns with the quick 180 the water does on that setup? I could do that pretty easy, just wasn't sure on the water flow that would allow? I am by no means a plumber and have little knowledge on flow, etc.
    Polaris robot
    TF100
    38,546
    That is the way that SWG has to be installed. Others go more in-line (like Hayward, Pentair) with the plumbing ... and they can be installed horizontal or vertical.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Quote Originally Posted by savagesix
    J.
    Yes, that is correct.
