Thread: Raised Spa Water Level Low
    I must have touched something I shouldn't have. I shortened the pump run time a few days ago to run from 11:00am to 4:00pm in the Easytouch settings. The past 2 days I have noticed that the spa water level is near the bottom of the border tile. The rest of the pool is fine. The spa is raised, if that makes any difference. It's not being splashed out, so it is draining into the pool.
    Any ideas of what to check?
    Thank you in advance!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    38,463
    Re: Raised Spa Water Level Low
    Is the spa lowering to the pool water level?
    Make sure the spa valves are closed all the way and make sure the check valve is working ... those are really the only path back to the pool.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Thanks jb, the spa water level drops about 1.5" from one day to the next. The spa is raised 18" over the pool with a waterfall.
    I just went to look at valves, and discovered a drip coming from under the collar of the part that has a red warning label on it. The other day I replaced the pressure gauge on top of the DE filter. I turned off the pump, put it in "service mode" then let air out by squeezing the tabs on the side. I may have also turned the base to let air out. I 'm pretty sure I did. I replaced the gauge, and snugged everything back up. Then I turned on the pump. No explosions, so I thought I did ok.
    I am including pics of the valves. One does look like it may be open a bit... but these automatically turn when I turn on the spa heater. I don't think I should manually force it. I don't remember it always being like this, but I can look back at older pics.
    Helen
    I did buy one of those liquid filled gauges, but it's not here yet.
    My pump always hangs around 18-20psi..on low speed. I have to turn the pump up to get a true reading. (I'm going to backwash but not until I get the leak fixed.)
    Helen
    Well, I fixed the leak.. we'll see how the spa water level is tomorrow. (fingers crossed..)
    My liquid gauge arrived today.
    Helen
