Thread: Pentair FullFloFX 2-way Diverter valve orientation
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    132
    The PB suggested mounting several FullFloFX 2-way Diverter valves vertically instead of horizontally. For my installation this will eliminate two 90 degree turns for each valve.
    My question is: Is there any downside to mounting a FullFloFX 2-way diverter valve vertically instead of horizontally?
    If I want to add automation in the future, can you mount valve actuators on a "vertical valve"?
    For those of you who have done maintenance on valves, would performing maintenance on a valve that is mounted vertically be a problem?
    Thanks for your help.
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    38,251
    Re: Pentair FullFloFX 2-way Diverter valve orientation
    Valve orientation does not matter. In fact I think more pads have them vertical as far as I have seen.
    Posted from my Droid with Tapatalk ... sorry if my response is short
