Results 1 to 8 of 8
Thread: new pool purposal- 20x40 inground vinyl with 8x8 spa
    Columbus Ohio
    178
    Hello all,
    We have been getting some quotes for a new pool, we sold our previous home which we had a vinyl pool installed, we learned a lot through the process and this place has been an amazing resource for us. On to the new home- we purchased 8 acres and are in the process of building our dream home with a vineyard, and we are planning on putting in a 20x40 vinyl inground pool with a partially raised spa. Most of the quotes we have recieved have been in the same range giver or take a couple of thousand.
    What we have decided on specifically so far is as followed,
    20x40 in ground pool with a 8ft deep end. We are set on doing the 20ft vinyl covered steps, limestone coping, an automatic cover. We are still trying to decide on the lighted deck jets and would LOVE any input on them as we just had the standard ones before. We are wanting to do a spa 8x8ft inground fiberglass shell, plumbing completely seperate so we can still use the hot tub in the winter and avoiding sharing equipment so we can do so. We are leaning towards using our previous pool builder because he did an outstanding job, he is right in the middle with pricing at 53k for the pool and 17k for the spa. He does include the gravel backfill, all of the water for the pool (because we will be on a well, we want a complete fill up.) We will also be doing the easy touch and salt water chlorine generator. 4 LED pool lights, Sand filter, VS pump, and a heat pump, 3 skimmers, 4 returns, and main drain and 2 inch plumbing. None of the bids include decking yet because we aren't sure which way we are leaning (stamped concrete, pavers, or ultimently I would love to have the full range bluestone). We already have a 20x12 covered porch going on the home for shade and entertainment and our landscape designers have put together a beautiful plan that includes an out door kitche, stone fireplace, and pretty much everything we have ever wanted outside.
    I know we would love any input on anything we may have missed, its a lot going on and just wanted some opinions on what we are looking to do. All of the equipment will be Pentair, and we had it previously and feel comfortable with all of it.
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Columbus Ohio
    178
    Re: new pool purposal- 20x40 inground vinyl with 8x8 spa
    As well, We want to keep with the french country theme, so any opinions that could help keep it along the french country would be great, any decorations or decking ideas would be very help full. Here are some pictures of the home and the covered porch (we are doing 3 french doors on the patio vrs the windows and one door) So you can all get a good idea of the theme we are going for.
    Also a side note, if you know of anything that would enhance the french country astetics on the house please let us know!! we are always looking for more ideas.
    Apr 2012
    151
    Make CERTAIN the vinyl steps have some sort of tread/texture. I have one customer that went the vinyl step route, but without tread/texture. THEY ARE EXTREMLY SLIPPERY. I had to install a handrail so that he could haul himself out of the pool. The handrail addition was not the most aesthetically pleasing, as I could not drill into the deck at that point because of some structural steel issues. I ended up using a top mount flange anchored in the concrete.
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Columbus Ohio
    178
    msumoose- Thank you for that tip! I did verify it does have the diamond tread on the steps so there is some traction!
    Nov 2011
    Moberly,MO
    1,010
    Depending on the brand of automatic cover, and pool wall manufacturer you may have to pour concrete at the top of the wall to make the warranty good. Also if the auto cover track is not anchored into concrete it will not be considered a safety cover. I am a builder and if you aren't enclosing the pool I wouldn't spend the extra for a laminar deck jet.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    I might suggest taking a look at the StoneMakers product which can be used for both walls and patios. It is concrete with additives that allow it to be formed into walls/steps, etc. without forms. Then it gets carved to look like whatever you would like, then stained to your specs. The same is true for patio/pool decking. It is carved and stained to your desires. So, though I'm not familiar with what patterns would be appropriate for a french country theme, if you find a look you like it can be recreated with this product. It is installed by licensed dealers only.
    My PB is more so a landscape/hardscape guy and he is sold on it if you can't afford real stone (we can't). We are going with about 1800 s.f. of decking and a 75' wall made of it. Our decking on the low side of the pool will be installed in the "turned down" method, so basically another 75' wall on the lower side, again carved/colored to our specs. For our application it was a little more than concrete, actually a little less than pavers and a block style wall and less than stone (though we never even priced that). Not sure how or why that was the case exactly regarding pricing but we hope to pleased. We are building in Jan/Feb in the MD, which should be interesting.
    I love your lot and I'm sure it will be fantastic when all is complete.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Columbus Ohio
    178
    Thank you for all of your input thus far! -
    Swimcmp- why would you not recommend the lighted deck jets if we arent enclosing the pool? As well, we are probably going to do a 3 ft walk on the side where we wanted the grass to meet the coping due to the things you stated above, and we have talked with a few people that have said its difficult to keep grass and such in that type of condition.
    bmoreswim- Thank you for that great tip! I googled it and its something we are going to ask our pool builder about- also our landscape designers because we think we are going to use them vrs the pool builder for the rest of the decking and landscaping. I can't wait to see some updated on your pool!!!
    Nov 2011
    Moberly,MO
    1,010
    My reason for not recommending laminars in an outdoor situation is in a breeze the wind will break the stream and then the light doesn't show.
