Thread: FC Levels
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    FC Levels
    I've read in this forum that a salt pool with a CYA of 70 should have a target FC level of 5. Everything I've read about chlorine levels indicates anything above an FC of 3 poses a health risk. Can someone please comment or advise?
    11,600 gallon plaster salt pool & spa, IC20 SWG, IntelliPH, cartridge filter, 2.7HP IntelliFlo Variable Speed Pump, Gas Heater, Easy Touch System w/remote, 8 roof mounted solar panels
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    22,550
    Re: FC Levels
    There are lots of posts here about that very issue. Surmize it to say that the 3 ppm recommendation doesn't take into account the effect of adding CYA to the water. In fact the industry still doesn't recognize the FC/CYA relationship.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: FC Levels
    Quote Originally Posted by bxcrwlly
    Just to add a minor note to this:
    My water routinely is between FC 5-8. My CYA is around 45-55 depending on how I read the test. I had one kid who was a friend of my daughter's ask me how I kept the pool so clean without chlorine. He thought he was swimming in fresh water.
    Our tap water has a much stronger smell of chlorine than the pool. Which is pretty much rational - since the tap water active chlorine levels are higher than the pool. The tap water has 1.5-3ppm depending on when and where I measure it - but zero CYA. The pool is consistently at 5ppm or higher. There's a chart around here that shows the actual "active" chlorine levels in various CYA/FC concentrations - and if I recall correctly the 5ppm+ I have is more like 0.1ppm active. The 1.5-3ppm tap water is much much higher than that.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Re: FC Levels
    Quote Originally Posted by UnderWaterVanya
    That is just TOTALLY AWESOME!!!
    Yay for TFP
    Yup, it's all about the sequestering properties of the CYA. It's certainly a beautiful thing!!
    The chart you're referring to is in the link that Richard320 provided.
    ChemGeek's HOCl to CYA Chart
    UWV, at an FC of 5 or 10ppm at a CYA of 50ppm. Your active Hypochlorous Acid (HOCl) would be 0.043 & 0.102 ppm of active, pure CL2. So you're somewhere in the middle.
    Can you imagine maintaining that with no CYA? WOW!
    You'd have to live by the pool. HAHA
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: FC Levels
    Also see this post which has links to some FC limits for commercial/public pools in different states that vary from 3 (Massachusetts) to 10 (Florida). The EPA limit for drinking water is 4, but that doesn't have any CYA. The state limits are higher mostly because of outdoor pools that use CYA, though the states don't regulate for an active chlorine level. If they did, then they'd be regulating for a minimum and maximum FC/CYA ratio since that's an approximation proportional to the active chlorine level.
