Results 1 to 7 of 7
Thread: Any Cleaner do true 90 degree corners?
    happyheathen's Avatar
    Sacramento CA
    225
    Back to playing with the idea of a cleaner - it just occured that many brag about how tight an intersection they can manage, but I haven't see one which claims to do a 90 x 90 corner - of which I have 2 - both are on a wall hugging the fence line, if that explains the complete lack of radius on the intersection of both south wall to east and west walls.
    There is a tiny radius between the floor and the south wall, but not much.
    Should I count on going out every 30 minutes and freeing the cleaner from the corners?
    The 3 steps are also square blocks, but are easily reached.
    As always, thanks for any info!
    dave
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    30,414
    Re: Any Cleaner do true 90 degree corners?
    Absolutely not.
    38,271
    What type of cleaners are you taking about? Most robot cleaners will reverse direction. So when it hits the wall and stops, it will eventually reverse direction and had away from the wall.
    Suction cleaners will not do this and I imagine that is what you are thinking of. I am not sure if pressure side cleaners reverse suction or not ... I doubt it.
    A robot may not climb the wall, but it should not stay stuck.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Sacramento CA
    225
    I've got a very noisy booster - looks to be mid-80's original.
    Using it was first choice - I'm leaning to the Polaris 280 - would its back-up valve keep it moving?
    If I can find a bargain on a robot, that would be my new first choice.
    The way the thing is plumbed (2-hole skimmer), suction would involve repeated connects and disconnects - either have a skimmer or have a cleaner, not both at the same time.
    Dave
    Sacramento
    Apr 2012
    Sydney, Australia
    6
    I have a square pool but with rounded edges at the bottom of the pool on the corners. i have a Polaris 280 and its great. it does get stuck in one corner which is at the limit of the hose (and i suspect if the hose was a foot longer it would climb the wall and move on) but my point is when it gets stuck in that corner the back up valve effectively moves it on.
    Regards
    Kev
    95,000 Lt (25,000 Gallon) IGP 12.5m x 7m & Seperate Spa 2.2m x 2.1m. Gemtex and tile finish Spa fully tiled. Waterco Micron glass bead filter S800, Viron P600 eVo variable speed pump. Viron Connect Pool and Spa Controller touchscreen. Chemigem D10 Auto PH/Chlorine Controller. Sunlover Oasis C25 Heat Pump for Pool & Viron 250 LPG Gas Heater for Spa. 7 LED Lights. Polaris 280 with booster pump. Pool Cover and Roller. TF-100 Test Kit and Speed Stirrer
    Sacramento CA
    225
    Thanks!
    Speaking of deals on robots - how about a Polaris 9300 for $100? Local Craigslist - the neighborhood listed is a "Pleasant Valley Sunday" type of place, for what that's worth.
    How badly could a person go wrong (assuming said person has access to a well- equipped shop with all kinds of tools)?
    For those wondering what one looks like: http://sacramento.craigslist.org/grd/3421617955.html
    No info other than "don't work; don't know why - but I'm sure it's an easy fix". Gotta love these folks...
    Dave
    Sacramento
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    I have an old Hayward Pool Vac suction type cleaner. I have a couple of 90 degree corners where the baja shelf and the steps meet the pool walls. The cleaner has never got stuck in the corners. It bounces off the wall a few times then heads off in a different direction. It has enough flow to pull almost any debris out of the corner.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
