Thread: Testing tap water
    Oct 2012
    Seattle, WA
    22
    Testing tap water
    I have the TF100 kit but have not yet tested my tap water but I just drained my spa so need to find a starting point. Is there any special instructions, i.e. is water temperature important? Also, how do I have find out if there are metals in my tap water?
    Thanks.
    -Drew
    16,000 gal, Indoor, fiberglass, sand
    38,343
    Re: Testing tap water
    Water should be room temperature, although does not affect much.
    Have a pool store test for metals. Kits are expensive and not needed often.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Oct 2012
    Seattle, WA
    22
    thanks
    -Drew
    30,426
    If I was on municipal water, I wouldn't go to much trouble to do a metal test...........if you have metals, it is almost always because you are using a well.
    Oct 2012
    Seattle, WA
    22
    okay... I won't worry about it but if I get a chance I might see if the pool store will test a sample for metals.
    -Drew
