Thread: Polaris 280 eating wheels - why?
    Feb 2012
    Dallas, Texas
    56
    I inherited a neglected Polaris 280 with my current house about a year ago. After spending the summer replacing various parts, I've finally got it basically running correctly - with one exception. On the side with the two large wheels and small wheel in the center, the metal drive gear is constantly eating the teeth on the inside edge of the front wheel. This does not happen on the other side (the "one wheel" side) even though there a similar metal gear meshing with the teeth on the inside of that wheel.
    I've replaced the bearings and all the wheels, and replaced the wheel with the issue 3 times. For about a week it works fine, then it starts turning circles. Sure enough, the teeth on that one wheel are worn down. Only fix I've found is to replace the wheel again.
    Any idea what's causing this?
    Thanks.
    IG plaster pool, 16000 gallons, Hayward DE6020 filter (120GPM) , 2.0 HP 230v single speed 1.3SR motor on Sta-Rite Max-E-Glas 1 pump, Polaris 280 (with Polaris 1.5 HP booster pump), spa.
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Polaris 280 eating wheels - why?
    The metal teeth on the drive shaft could be bad and too sharp for the plastic.
    Another thing is that the wheel is adjustable and can be moved up or back slightly. If the wheel is riding too tight on the drive shaft it could cause it to eat into the wheel.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Feb 2012
    Dallas, Texas
    56
    Thanks for the reply. I forgot to mention that I tried the wheel adjustment - loosened the screws and pulled the wheel to where the metal shaft was as deep in the teeth as it would go.
    So maybe I need to move that back? Since it is basically lopping/grinding the points off the teeth on the wheel, I thought it might not be meshing deep enough.
    The teeth on the shaft look OK, but I may as well just buy a new shaft - they're only $20-25.
    Aug 2007
    near the swamp
    806
    The turbine should be 3/4's engaged into the teeth, not anymore.
