Results 1 to 10 of 10
Thread: how to reattach a thermostat sensor
    Apr 2009
    Media, PA
    42
    I replaced some of my PVC and have to reattach the thermostat. What type of glue/cement should I use to reattach? it looks the the original glue/cement was a rubber material?
    22,553
    Re: how to reattach a thermostat
    We need to know more about what you're talking about. Do you mean pvc piping? If so, what is it going to? And by thermostat, do you mean thermocouple or thermistor? Or something else?
    Apr 2009
    Media, PA
    42
    Yes, PVC piping between pentair filter and pool heater. I've replace this section of PVC and the old PVC line had a thermostat for the heater inserted into the PVC (thermocouple). There was about 1/4 drill hole in which this was inserted. I need to replace this back into my new PVC line. The old one was secured with a metal clamp and some sort of rubber sealant of some kind. My question is what is that sealant? Hope this clarifies...
    22,553
    I'm not sure what the compound was. Can you post a pic of the sensor? Maybe we could suggest a better way to install it.
    Apr 2009
    Media, PA
    42
    The attached images show the heater thermostat (which gets inserted into the PVC pipe through about 1/4 drilled hole), and a picture of the prior PVC pipe with the compound showing on the pipe.
    22,553
    That just looks like silicone sealant. Just get some 100% silicone sealant and run a bead around the hole and place the sensor in the hole and squash the sealant enough to seal good and let it cure overnight without any water or pressure on it.
    4knights's Avatar
    NE Kansas
    419
    I have a hose clamp wrapped around the pipe and over the sensor, no leaks since the sensor has a gasket/o ring. The silicone will act as your gasket and the hose clamp makes sure it stays in place.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Apr 2009
    Media, PA
    42
    Sounds like a plan, Thanks!
    Apr 2009
    Media, PA
    42
    Final Pics - project complete. Thanks!
    22,553
    Looks good.
    I'm sure someone will appreciate that in the future.
