Results 1 to 7 of 7
Thread: Weird foaming!!!
    Weird foaming!!!
    I'm trying to keep my 2012 Hot Spot Relay in good condition and so far it has looked and ran great, but in the last week it has started to foam horribly but ONLY when i allow air flow into my jets. When they have no air flow through them the tub looks amazing. Any ideas? I thought maybe it could be a problem with having to much antifoam in the tub and maybe it just started collecting a film on top but their is no sign of any film on top. I know most people would say drain with a spa problem like that but draining is a huge hassle in my location. Any ideas would be greatly appreciated.
    Home and Roam 48" waterline 27' Round Above Ground Pool (acquired when we bought our house - pool is in the middle of a large deck
    Gallons approx. 15,054
    Hayward 100lb sand filter - sand replaced end of last season (2011)
    Hayward pump
    All seals and gaskets for pump and filter replaced this year
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Weird foaming!!!
    What's your water's hardness level? Water hardness will reduce foaming. We usually recommend 120-150 ppm Calcium Hardness, but with regard to just reducing foaming, magnesium hardness works as well so this is one case where Total Hardness would be relevant. On the other hand, if you are using anti-foaming or other products, who knows what could happen.
    Oct 2012
    209
    How long has it been since you changed your water?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Knoxville, TN
    41
    Could be coming from your swim suits being washed too much with the normal amount of detergent. Try not washing them, hang them up outside or in the bathroom to air dry. Or use half the amount of detergent to wash ONLY the suits by themselves.
    Good luck!
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    ^or better yet, don't wear swimsuits
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Swampwoman
    LOL do your children know this about you?
    Sent via Tapatalk...
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    ^Advantages of the empty nest...but yes, he knows to knock first before coming outside
    Helpful Links:
