Thread: Pool crete bottom problems
    I'm putting in a 20x40x45 L shaped pool
    Steel wall Vinyl liner pool, we got about 3/4 of the bottom done before we ran out of crete 120 Bags
    so of course nowhere to buy it in south Georgia so I ordered another 50 to cover the rest
    which took weeks to get here so 3/4 of the bottom is done and been sitting with no liner for 3-4 weeks
    Problems
    1: noticing hair line cracks on some of the deep end walls and around the break
    2: pool crete is unlevel with trowel marks and divers, looks awful
    we've triend rock sanding it down to fix trowell marks and to try to fix some of the unlevelness
    while it looks better it is far from perfect
    my question is now that we've taken some of the height out of the bottom could I put a skim coat of pool crete on top of what is already there and try to fix some of the problems and if so how thick should it be?
    The company i bought the kit from said he saw no problem with that
    but thought I'd throw it out there for anybody that could give me advise
    Found this forum a couple of weeks ago and have been like an addict since
    thanks in advance for the help
    38,305
    Re: Pool crete bottom problems
    Welcome to TFP!!!
    Please do not duplicate posts (I deleted your other one).
    While I do not know enough to offer any help, someone will eventually be along to offer their thoughts.
    30,424
    I doubt they have ever installed poolcrete, then.
    1. Be aware that whatever you do, it will be almost impossible to get a really smooth surface with poolcrete. You can usually get it acceptable for daytime but at night, it will look like craters on the moon when you turn on the pool lights.
    2. Skimming will be very troublesome and I wouldn't do it. It wont bond well and it will tend to "roll up" as you apply it, I'm afraid.
    3. going over it once more with a rock and taking out the high parts may be helpful but, above all else, prepare yourself when you look at it with the pool lights on.
    4. The cracks are irrelevant. There are no technical issues with uneven poolcrete....only aesthetic.
    Jul 2012
    Blountsville, AL
    59
    Just want to say that my new pool has bad trowel marks in it, also. During the day, it looks perfect. At night, moon craters is right
    20' x 38' x 40' Lagoon, 38K Gal, Vinyl, Aqua Plus control, SuperFlow 2 hp pump, 3.7 sqft sand filter, T-15 SWG
    2 ColorLogic 4.0 LED lights, Polaris 280, TF-100 test kit, Finished in September 2012
    Master Spas Twilight 8.2
    Oct 2012
    209
    Get it as even as you can....but as duraleigh stated, you will never get it perfect. I have seen near perfect pool crete and terrible poolcrete. The good thing is that once the liner is in it is hard to actually "see" the difference...until the lights are off. Small cracks are fine....big cracks and ground water are what you need to watch out for.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
