Thread: Soap in pool
    May 2008
    Fredericksburg, Va
    3
    Soap in pool
    I needed to raise my alkalinity and bought what I thought was arm and hammer baking soda. I needed 5 lbs so I dumped 5lbs in. I think what I got was some type of arm and hammer detergent because this morning I have a lot of soap suds on top of the pool. Any ideas for cleaning this mess up?
    [i][color=#BF0040]27' x 52"....1.5 HP hayward pump 200lb sand filter.....finally building our deck :)
    I cannot help you with the suds, but for future reference, Baking Soda is found in the grocery section, ORANGE box, usually with flour, sugar, and other baking supplies.
    If you are ever looking for Washing soda, (I think to raise pH and TA together) that is on the laundry side, in an YELLOW box.
    Arm & Hammer makes a Laundry detergent (which is what you undoubtedly bought) in an ORANGE box.
    Someone will be along... this has happened before!! And in case I have not said it yet,
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    The most important thing is to monitor and maintain your FC level. You will probably be needing extra chlorine for a day or two, which will help break down the soap. If it persists you can try an enzyme product to speed up the breakdown.
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    OOPS
    So now you put in the dirty washing and start swimming
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
