Thread: Pool winterized - Now the real work starts
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Now that my pool is winterized I have some changes to make. I want to hard plumb it and bond it. I know how to bond it and have all the stuff. However, I need to know some things before I hard plumb.
    Other than the straight schedule 40 1.5" pipe, 45 and 90 degree pieces, the PVC cleaner and glue, and 4 unions, do I need anything else? My bonding is going through the skimmer and all I have is the pump and filter, no heater.
    I also plan to move my pump/filter from its current location to the side of my house. The distance is less than 20 feet.
    Any advice?
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Pool winterized - Now the real work starts
    The plumbing running from the equipment to the pool should be buried 18" deep. Be sure to use pvc glue on both pipe and fitting to insure a good seal. If you use any male or female adapters use teflon tape and teflon paste to prevent leaking. If the low tempature in your area gets below freezing use a pipe insulater on the above ground plumbing and run the pump at night when the temprature is the coldest.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I did not know about the 18" deep part. The temps here get below freezing but not while the pool filter is in use. I will blow the lines out and cap them off during those times. Thank you for posting.
    38,301
    By cleaner, do you mean primer? There is a difference. You certainly want to use primer & solvent (glue). The cleaner is not really needed IMO since you are using new/clean PVC.
    Going 18" deep will help ensure that it is not accidentally hit while digging later and help get below the freeze line (although may not be applicable for you). One other "safety" would be to run an 18 AWG tracer wire above the pipe. That way someone could always determine where the pipes are run (like they do for electrical and gas lines). No code requirement for this ... but while the trench is open ...
    4knights's Avatar
    NE Kansas
    419
    Got to agree with JBizzel on running a wire or possibly 1/4" rebar above the line so you can find it later.
    Not sure what code is in your part of the country (call local building department- no charge for answers) but here, all waterlines are 3 feet minimum burial depth and electric in conduit is 18" min with 24" preferred. Probably due to freezing.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Yes, I mean primer. Sorry, I know how to use the stuff because my late step-father was a plumber and passed his knowledge on to me but he wasn't very technical. lol. I call it cleaner only because he did. It's the primer. I have some 4 gauge power cable left over from a car ignition grounding kit I used to make and sell that will run the length of the pipe. Although, my sprinkler system is about 10" under ground and runs all over the place it seems. I will try to get around it as well so I am hand digging my trench. Fun!
