Thread: Bonding question
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Bonding question
    Trying to figure how much wire I need to bond pool.
    Does this sound right?
    24ft dia. pool, buried copper wire approx. 2ft away from pool.
    26x3.14= 81.64ft
    plus extra for attaching it to four places to pool, water bonder, and back to pump.
    Does this sound correct?
    Thanks in advance
    Jeff
    Jeff
    Oct 2012
    Central Ohio
    180
    Re: Bonding question
    On my 24' pool I used roughly 110' of bare copper #6 wire.(#8 wasn't available)My equipment is 8' from the pool.The electrical inspecter where I live wanted the bond wire to be 18"-24" from the pool 4-6" deep attached to 4 places on pool bottom track equally spaced(I have resin uprights and top seat),he also wanted it to be 1 single piece of wire with no splices(not code his preference)luggs had to be direct burial listed.For my water bond I used an 1-1/2" X 6" stainless steel nipple attached to the suction side of the pump and a grounding lug attached to the nipple. http://www.lowes.com/pd_72271-15527-413 ... +grounding Basically started at pump ended at water bond at pump.
    good video showing AG pool bonding. http://www.youtube.com/watch?v=x6KMtrIa2x4
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    22,548
    CB's 110' sounds about right.
    If you draw a circle with a 2' bigger radius than the 24' pool you actually wind up with a 28' diameter circle. That makes it take 88' just to encircle the pool and then you have to add 8' just for the 4 attachments to the pool and that makes it 96' minimum just to bond the pool wall.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Thanks guys! I thought I was on the right track.Just wanted to make sure.
    Jeff
