Results 1 to 7 of 7
Thread: Hayward Sand Filter Questions
    Columbia, SC
    22
    I have a Hayward sand filter (I'm not near it now but I believe it is a pro-series. In any case a standard sand filter with a control valve handle at the top to move between filter, waste, backwash, recirculate, etc.) It has been in use for seven seasons with no maintenance other than backwashing and rinsing. I know it's not working like it once was and I notice two things in particular. The pressure gauge rarely moves (it is working properly because I add DE occasionally and it moves then) and it simply does not clean the water as efficiently. What is this a likely sign of? Does it just need some maintenance or is the sand channeled? Does the sand need to be changed? Another problem is I see no way to remove the top without cutting the PVC pipes attached to the valve because they are firmly cemented together. Is that standard practice?
    20K gal, vinyl, 3/4 HP pump, Hayward sand filter
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Re: Hayward Sand Filter Questions
    No, there's no need to ever change your sand except under rare circumstances. IE. so gummy and gooey do to lack of maintenance for years and years and a filter that's older than the town. Yeah.
    It sounds like you need to clean & resettle the sand bed. See my sig for how to do that.
    But you have to pop the top, or 2 halves in order to do so.
    As for the pipes being cemented in place, I'm not sure on that one.
    I do know that there are usually hand tight, ribbed slip rings that slide over the joint at the multi-port valve. Just undo those and some wiggling of things and you should be good.
    But beyond that, someone else will chime in and give you some info there.
    Do you have a picture of it?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Oct 2012
    Central Ohio
    180
    You may need to cut your piping and install a couple unions so you can remove your multiport valve to access the inside of your filter.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    30,424
    When you say the pressure guage rarely moves, tell us more.
    What is your normal operating psi? Does the psi go to zero when you shut it off?
    Probably need to cut loose the multiport and inspect the sand bed (re-install with unions) to find the issue but answer the questions about your psi first. Sand beds should be inspected yearly and cleaned if necessary.
    Columbia, SC
    22
    The guage stays at 11 when the pump is running and it drops to zero when I shut it off. I've not backwashed for short increments (hours) and long periods (weeks) and it always goes immediately back to 11 and stays there. The only time it goes up, and it typically happens quite fast is when I add DE. (Perhaps I'm adding too much or adding it too quickly.) I periodically add DE to remove dead algae (I've had algae outbreaks which is another story) but it requires more monitoring as the gauge reading will go up to 25 or so if I don't watch it. In case it is significant after I add DE and the gauge reading gets up high I begin to get air in the pump, I figure because it is straining too hard to suck the water in at that pressure level. Something else I just thought of. Since the begining of this past summer when I first turn the pump on water often squirts out the flange clamp where the control valve meets the body of the sand filter.
    I will post a picture of the piping but I'm pretty sure I will need to cut them to get at the sand.
    Thank you all for your help.
    30,424
    It sounds to me like your filter is working correctly. Why are you adding DE? Using it to remove dead algae is a potential problem.
    It sounds like you have some inconsistent management procedures that is causing your pool to give you problems. Can you post a comp[lete set of test results?
    22,551
    It could be that the sand is channeled but since adding DE raises the pressure it doesn't sound like it. How much DE are you adding?
    You should only add about a cup full. If you're not adding much more than that and the pressure is rising really fast it's most likely because there's stuff in the water that the DE is catching.
