Results 1 to 7 of 7
Thread: Nitro Wall Climber
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Nitro Wall Climber
    Hi guys,
    Have a Nitro Wall Climber was new at the beginning of the season 2012. Has worked great on a weekly basis. Just came back from a trip and went to use it. Started fine like it always did, then for some unknown reason quit. Did the usual inspection and cleaning, could find nothing visually obvious. Power pack works with the green or red lights. Anyone else experience this? Ideas before I call the company?
    thank you
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Nitro Wall Climber
    When you cycle the power does the pump or the drive motor come on? Normally the pump comes on first, then the drive motor. The pump sometimes stops, but the drive motor continues. Then starts up. Good indicator light on the power supply?
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    No pump, no drive motor operation on the unit itself, all indicator lights on the power supply red and green work fine.
    Steve-Liteguy
    Apr 2011
    Murrieta, CA
    2,360
    Sounds like you're going to have to call the manufacturer.
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Well...whats really annoying is ZERO customer service form the company that distributes the Nitro Wall Climber.
    I really like the unit at the beginning of the season, but now, I get ZERO response as if the company does not exist. The unit I have was new and in 6 months has died, using it once per week +/-
    Are the nitro wall climber people members here? Sure would appreciate a response. If not they are done in my book.
    Steve-Liteguy
    30,421
    Hi, Steve,
    This forum is probably not the best place to get a response from a manufacturer. The vast majority of members here are pool owners like you and me.
    I have no idea who even makes your unit but I would sure call them directly (sounds like you are going through a distributor?) and give them an opportunity to help you troubleshoot.
    Apr 2011
    Murrieta, CA
    2,360
    Not sure if this is the info you have but I hope it helps.
    http://smartpool.com/website/Support/Co ... fault.aspx
    We are also available to assist by phone Monday-Friday 9am-5pm EST at 732-730-9880.
    Smartpool, Inc., 687 Prospect Street, Lakewood, NJ 08701
    When I had a problem with my unit the "whiskers" they sent me out a replacement set. No problem. Sorry your having troubles.
