Thread: AWR GFI receptacle
    AWR GFI receptacle
    On my list of fixit items from the inspector left me this one:
    GFI receptacles shall be AWR type and have a bubble cover installed.
    I've taken care of the bubble cover but I'm a little confused what he means by AWR type? The receptacle I have test out correctly when tripped. There is a little green light in the top right corner that is on when its working, when tripped it turns off.
    Any ideas on this? Thanks..
    __________________________________
    16x32 IG Vinyl Pool : Sand Filter : 1hp single speed Pump
    Electric: 100amp panel box
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: AWR GFI receptacle
    I'd assume it means the outlet itself needs to be weather resistant
    Oct 2012
    Central Ohio
    180
    I think what your inspector is saying,is the cover needs to be an in-use WR(weather resistant)cover with a weather resistant outlet.Unless you have aluminum wiring,lets hope not.
    http://www.lowes.com/pd_315348-334-TWRV ... g_rating|1
    http://www.lowes.com/pd_147292-53911-2C ... g_rating|1
    http://www.lowes.com/pd_238217-53911-2C ... g_rating|1
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Thanks for the help. I purchased the correct type of GFI outlet and that part passed the inspection. What didn't pass was the type of wires I was using and the fact that the pump and light were not on GFI circuits. Now I have purchased them and replaced what was needed I should be done and approved tomorrow morning.
    Thanks for all the help.
