Thread: Still undecided on pool
    Hi All
    I am new to this forum, I am looking at getting one of the intex ultra above ground pools,
    Still a little un decided if I should or shouldn't get one, I own my house and live in it my self,
    If I go for one I would have it salt water to save on chemicals.
    What sort of things should I be taking into consideration when putting one in?
    I have been told to expect $100AU in power and upkeep.
    The pool comes with a cover and will be up all year round.
    Regards
    Bazzy
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Still undecided on pool
    Salt does not save money in the long haul with larger systems but the small Intex systems are pretty cheap so it might save you money.
    If you do get an Intex system disconnect the copper bars.
    Sent via Tapatalk...
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    The single most important thing when putting a pool up is getting the ground level.
    You cannot determine level with your naked eye, you may be able to see if it's flat but level and flat are 2 different things. There are lots of videos online showing proper pool set up, watch those and get educated on the proper steps.
    A pool that is out of level is a risk to people and property.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Check local codes and home owner association rules so you don't get more expense then you plan for. There are several threads here about what people have run into.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We have a 9x18 with salt. So easy to maintain its crazy. I spent the summer floating in mine while my niece spent all summer trying to keep her water clear. Salt water is the way to go. As others said level level level and then relevel. And don't use cement blocks. One of ours busted and we had to empty and start again. We love our pool and will be getting a bigger one when this one goes!!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
