Results 1 to 8 of 8
Thread: DIG 220 Intermittent Error Messages
    Hi,
    I have a DIG220 and it is about 6 years old. I very recently replaced the cell with a Compupool and it worked just fine for about a month. I now intermittently see Check/C together with Low Amp error messages flashing in alternate fashion. Sometimes the messages show up and other times they do not. I cleaned the cell but as can be expected after a short time in use it hardly had any scaling. It seems to be chlorinating but I am guessing not too efficiently. I had my water tested and adjusted all parameters as suggested. This did not change the errors. I checked both fuses on the main board and both tested fine.
    Any insight will be greatly appreciated.
    Thx
    Andre
    Re: DIG 220 Intermittent Error Messages
    Read some more and figured out that there are 3 badly bulging and discolored 1000 mf caps on the board. I'll be replacing them soon.
    Think you may have missed 1; pattern is 4 bad caps. 3 grouped together on left and the upper of the 2 to the right of those.
    10k gal conc. in-ground
    DiamondBrite cool blue
    Pentair Cartridge filter
    Hayward 3/4 HP pump
    Pool Pilot Digital 220
    Hayward Navigator Pool Shark
    I ordered enough to change all of them, and I think I should just do that. The one you are referring to is actually still nice and light blue, no bulging and no discoloration. Makes sense to replace all while I have the board out. Thanks for the suggestion!!
    Success!!
    Replaced the capacitors last night and hooked up the board this afternoon. Powered up perfectly, no smoke or explosions
    Red l.e.d. does not flash anymore. Put it right in Boost mode and it's running like a champ. I hope it stays this way.
    Here is a link to where I got the caps : http://www.ebay.com/itm/370524149571...84.m1497.l2648
    If anyone is interested, these are aluminum, electrolytic polarized capacitors, just in case you are shopping at Digikey or Mouser. They have radial leads.
    After running about an hour, the board was a bit hot and I would have expected the fans to come on. Can anyone tell me if they run all the time, or just when cooling is called? Also, what are the specs on the fans in case I need to get two.
    Thanks
    JoshU's Avatar
    New Orleans, LA
    543
    Depending on the software version your fans may or many not operate continually. Older software versions would have the fans running whenever the unit is powered whereas newer software versions power the fans only when the cell is active. The fan assembly is AutoPilot part # 630.
    If the fans are running please post back here and I will give you some diagnostic info to run a test to see if everything is running okay.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Quote Originally Posted by fish7days
    Success!!
    What's the temperature rating of those capacitors? I got those rated at 105C but saw plenty rated for 85C.
    Figured the higher heat tolerance would be an asset in that enclosed box with 2 tiny fans.
    Hayward 3/4 HP pump
    Bad news for Pool Pilot Dig220 owners: Your unit in all probability is afflicted or prone to power board problems due to failed/failing capacitors.
    Good news for Pool Pilot Dig220 owners: The unit is easily and inexpensively repairable by anyone with minimal soldering skills.
    Overall score for the unit: Excellent!
    Hayward 3/4 HP pump
