Thread: Conversion from Bromine to SWG
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Asking for my Mother-In-Law.
    She has a gunite I/G that is currently Bromine and she wants to go to SWG.
    Is this possible without draining all the water?
    What other complications might she face?
    Heard that the pool bottom may lift if drained.
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    38,452
    Re: Conversion from Bromine to SWG
    Well in reality you would be switching from Bromine to Chlorine. Then you would make the appropriate adjustments (salt, CYA) to start using a SWG.
    Looking through a few posts, it appears that you would indeed have to replace the water to get the bromine out ... otherwise any chlorine you add to the pool gets converted to bromine.
    Whether complications arise when draining a pool is mainly due to the underground water level. If the ground water level is below the pool, then the pool will not float. Here I have had 2 different pools completely drained with no issues, but I think the water level is a few 100 feet down.
