Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: BBQ Grill Island build
    sammm's Avatar
    North Richland Hills, TX
    257
    Hi all...I'm planning the build of my 'L' shaped BBQ island. I plan to use steel studs for the frame, and have been looking for info on best practices/tips/techniques when using them. Has anyone come across any info like that?
    It seems the 2.5" studs are recommended, and hardiboard is OK to use as a skin. I do plan to cover the outside of it with a stone veneer of some sort.
    I'll keep this thread updated as my project progresses....thanks all!
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    sammm's Avatar
    257
    Re: BBQ Grill Island build
    Here's the initial layout I'm thinking of. The tiled floor part is actually part of a covered patio, so the fridge will be out of the weather. The 'legs' of the L are approx. 5' long and 30" wide.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    That doesn't look like much space between the wall on the right side of the photo and the bar...
    What are your plans for countertop?
    Aug 2010
    New Caney, TX 77357
    184
    Quote Originally Posted by sammm
    Sam,
    What I mostly did was go back to the beginning of the Outdoor Kitchens board on TroubleFreePool and read through all the threads and studied the pictures posted by others documenting their builds. I made my own plans (sketches) based on what I learned plus working around the equipment I wanted to install in the available space. I picked up most the of the techniques for working with the metal studs and hardie-backer that way. I bought a DVD on building outdoors kitchens from The Barbecue Coach but it was not very useful for a full-on DIY project. It was mostly addressing the products he sells and how to put the modular units he builds together. I also used YouTube and DIY websites to get some tips on doing the tile and stucco. There are some YouTube videos documenting some of the techniques for working with metal studs as well. If you have any questions post 'em up on the board.
    There is also more info on this board: http://www.bbqsource-forums.com
    20K gal, inground with attached spa, pebblefina plaster (bella blue), flagstone coping, moss rock waterfall, Sundek - Indian wheat, (2) Jandy PHPM2.0 (filter pump and waterfall), Jandy DEV60 DE filter, Polaris 280 pool cleaner, Polaris Halcyon PB4-60Q booster pump, Polaris 1.5 HP Air Blower, (2) Jandy WaterColors LED lights, Jandy LXI400P Heater, Jandy AquaPure PLC1400 SWG, Jandy AquaLink RS PureLink Controller and PDA.
    sammm's Avatar
    257
    Quote Originally Posted by Melt In The Sun
    The island will be right up against the house (brick wall) on that side with no room in between. I'm leaning towards granite counters, but am open to suggestions.
    sammm's Avatar
    257
    Thanks for the info Stevereno!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I think what MITS was saying, is that the walkway on the right side of your drawing, between the right leg of the L and the corner of that outer wall would be awfully narrow. I think so too. In fact, I saw the same thing before I even saw his post.
    I would move the bar forward, all the way to the edge of the concrete patio, right where the planting bed starts. This will give you more room between the L leg and that corner wall.
    As it is, it looks like one person could barely fit through there. Being that'll be the only way I presume between the inside of the house and the backyard, it's going to see a lot of foot traffic.
    If you have to carry platters out to guests and what not, that's going to be pretty difficult to get through there while carrying something.
    For counter tops.
    I would do Corian, as it can be resurfaced pretty easily. Granite and marble can't, so any cut marks from food prep on the surface are permanent. People always seem to think they can cut on countertops, especially the latter two types. It dulls your blade edge, not to mention kills the surface.
    Another thought would be, pardon my lack of "name" for it, those artificial poured concrete counter tops with an innumerable number of finishes that can be applied to them.
    You can do these yourself, I know a few DIYers that have done it.
    I believe they can be resurfaced as well. Ground down, polished, finished then re-glazed. Just like the Corian, except for one extra step.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    sammm's Avatar
    257
    Quote Originally Posted by y_not
    I see what y'all are talking about now. That's a pillar in the middle of the covered patio. (I've attached another picture with a different perspective.) You can see the blue-tape outline to the left of the patio.
    As is it now, that opening is around 25" wide or so. We have debated about blocking that pass-thru entirely, but I don't want to have to walk around to the other side of the patio (around the furniture) to get to the pool from the grill.
    That outer edge of the island will have a raised bar ledge as well.
    Oct 2009
    3,899
    Ok I see. From your first photo it looks like you can scoot the whole thing out maybe another foot from the pillar...I would still probably do that.
    For counters, consider tile as well! Not difficult, and lots to choose from.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    WoW! Yes, this makes sooo much more sense now.
    Indeed that'd be a drag to have to traverse all that patio furniture just to get to the pool.
    I agree with MITS, move the island out as far as you can from that pillar to give yourself maximum walkway space.
    Looks good otherwise, I like the positioning of it.
    Silly question, not related to the thread but the forum. Does your pool water look green or is it me?
    Even against the shallow white steps it looks pretty green. Well clear green.
    Funky light?
    sammm's Avatar
    257
    Funky light?
    Funky, early morning light....the pool is clear (thanks to BBB! )
    Thanks for the comments everyone...keep them coming and I'll show my progress.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Good to hear!
    sammm's Avatar
    257
    Back from the dead!
    Now that my pre-req projects are done (and it's getting warm), I'm ready to start my build.
    My first question is can I use the metal studs sold at the big box stores? It looks like they are 24 gauge, and what I've read recommends at least 20 gauge studs.
    I do plan to cover it with backer board, and then put a stone veneer over it. If I do need 20 gauge, where do I source them from?
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Back from the dead!
    I've seen plenty of builds with the 24 gauge studs, so you should be alright with those. I'm also having the same problem as you, only being able to find the 24 gauge studs at Home Depot. Here in CA, they just haven't taken off that much, so nobody carries them. If I had my choice, I would build most of my island with 20 gauge 2 x 3 studs, so I could gain the extra two inches inside the cabinet.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Oct 2012
    Central Ohio
    180
    For the studs try your local supply carpentry houses,Dry wall supply house.Stop by a commerical jobsite while their still framing the out side walls(for structural studs,heavy gauge) framers always have scrap. i.e. http://www.jbmaterials.com/product_steel.html http://www.southwesttexas.com/products.aspx
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    sammm's Avatar
    257
    Thanks for the info everyone. I went with the big box metal studs, and will reinforce the areas as needed.
    The counter tops will be at 36", and the bar ledge will be at 44".
    Sunny SoCal
    592
    Build looks great so far!!!
    Did you consider using Trex (or cheaper equivalent) for your base, instead of using the pressure treated lumber? The composite type Trex will have no rotting issues if water ever gets to it.
    Also, I helped a buddy move yesterday and we happened to stop at Home Depot about 35 miles from my local store. They had a bigger selection of the studs and also carried the 20ga. Might try calling around or speaking to the order desk to see if any other store has them near you. I'll probably end up getting the 20ga 2 x 4 if I can't find the 20ga 2x3's that I wanted to use.
    Keep up the good work... I'll probably start my project within the next month.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Quote Originally Posted by Killer95Stang
    I agree with Killer95stang. Trex is the way to go for baseboards.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    sammm's Avatar
    257
    Thanks guys...I wanted Trex, but it was special order only at my local HD.
  20. Back To Top    #20
    Jul 2012
    New Mexico
    66
    Keep us posted if you wouldn't mind. I am going to build mine this fall. Thanks!
    J.
    In New Mexico 20'x36'/3.5' to 8.5'/32,000 gallon/IG gunite/plaster
    Pentair WFE-4 pump/Pentair CC420 cartridge filter/Raypak 266A heater
    2 Pentair Intellibrite LED's/6 Aqua arches
    Coverpools cover with hidden lid
    1,500 sq ft stamped concrete deck
    Polaris robot
    TF100
