Thread: Unbelievable Chlorine consumption
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Unbelievably low, that is...
    I checked the pool with just the color block on Tuesday last week. It looked to be a little low - maybe 3.5-4. I dumped in about half a gallon of 12% which should have kicked it up to about 8. Left for Vegas Wednesday morning. I heard it was overcast at home from my wife. I got home late Friday, to some drizzle. It drizzled more on Saturday. Sunday was grey. I fished about 50 worms out of the pool and did nothing else. This morning I checked things and vacuumed. FC 6.2, CC .2
    Half a gallon a week? I'm loving it!
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: Unbelievable Chlorine consumption
    Nice! Gotta love low maintenance!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Richard320
    What is the water temp these days? I'd guess a lot warmer than here!
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by UnderWaterVanya
    A refreshing 58 degrees!
    Aug 2010
    Dallas, TX
    4,052
    I'm down to running the pump 4 hours a day, and still holding 4ppm with the SWG, even with some leaves in the pool at all times. It's not that I don't get them out, they fall faster than I can remove them!
    Jun 2012
    Mint Hill, NC
    2,589
    Wow - that's lower than expected.
