Results 1 to 14 of 14
Thread: Problem with Sour Smell
    Hey All --
    I've been getting a sour smell around the top edge of my tub at the front. I've tried wiping it down with Clorox wipes, and have also used water from inside the tub (after adding chlorine up to 7ppm), and neither of those have helped. Yes, I've also wiped down the cover in that area. Does anybody have an idea of something better to deal with the smell? Maybe a rag with almost pure chlorine?... That's probably a bit harsh, but the smell really is unpleasant.
    Thanks!
    Dave
    Oct 2012
    209
    Re: Problem with Sour Smell
    Is this a hot tub? In ground or in the deck?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Sorry -- this is a 2-year old Jacuzzi Hot Tub (J-355). Haven't had any real issues until this one crept up. Also, I just started the BBB method about a month ago. I had been using Aqua Finesse, but then I found this forum and became educated.
    Oct 2012
    209
    Is it leaking...or is.it set in something
    It is above-ground - no leaks that I see. The ground is dry all around.
    Oct 2012
    209
    Have you changed the water or shocked it recently?
    Water is about 4 weeks old. I chlorinate to about 5ppm after each soak. It never gets below 1.
    Oct 2012
    209
    With the high water temp of the hot tub and the small volume of water you need to keep it around 3 ppm. Youve been cleaning the filter I suppose.
    Post-soak, I chlorinate to about 5 ppm.... by the time I soak the next day it is around 1 ppm. Yes, the filter is clean.
    To be clear, the smell isn't coming from the water... it smells perfectly fine. The odor is coming from the surface of the hot tub above the water line in only one area of the tub.
    Oct 2012
    Katy, TX
    35
    Is this a fiberglass unit? Could something have crawled up into/under it and died?...or nested?...or defecated?
    15,000 gallon colored plaster in-ground with spa-spillover
    Hayward Tristar 2-speed 1.5hp main, Hayward Tristar 1 speed 1hp water feature
    Hayward Cartridge Filter C4030 & Tiger Shark
    Hayward ProLogic Automation & Hayward 400k BTU Heater
    Stenner 45MPHP10 Peristaltic Pump
    nope. Shell is intact and inside is clear.
    Oct 2012
    Katy, TX
    35
    Quote Originally Posted by Dave_J
    No - meant behind the shell. Between the shell and deck...where the plumbing is etc.
    Right -- that's what I meant -- behind the deck all is clear. I've opened up the motor access area and there's nothing unusual in there.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Have you sniffed around back there too?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
