Thread: Testing PH during shock
    Broken Arrow, OK
    24
    I just opened my pool today - slightly green. I shocked it to 16 and then tested the ph. The PH was way too high 8.2. Does the high chlorine level make the ph temporarily high? I tested the ph a few weeks ago before I took the cover off, and it was 7.6. What would cause my ph to go up so high?
    Test results today:
    FC: 16
    CC: 1
    CYA: 50
    PH: 8.2
    Michiele
    Newbie pool owner
    25,000 gallon inground, vinyl lined pool, sand filter
    30,414
    Yeah, most likely a result of the high chlorine. That initial dose is probably down below 10ppm now so you could test pH again before adding more chlorine and should get a fairly accurate test result (if it's below 10ppm chlorine)
    PS - I'd dose your chlorine alittle bit higher (20-25). It drops so quickly when you first put it in, it's hard to keep it above shock value.
    Butterfly's Avatar
    South Carolina
    10,045
    Testing for pH w/chlorine over 10 ppm gives inacurate results. Wait until your FC is below 10 ppm to test for pH.
    EDIT: Dave, apparently great minds think alike :P :P :P
    You're done SLAMing when:
    Broken Arrow, OK
    24
    Thanks for the replies. I was hoping the ph test was just inaccurate with the high chlorine. I just upped the chlorine to 20 a few minutes ago. I will bring it up to 20 - 25 tomorrow morning. Thanks
    Michiele
    Newbie pool owner
