Thread: Pool bids in Houston
    1st bid:
    Pool with following spec: 39,100
    • Free form: 40'x21', 720sqft, 3.5'-7' deep
    • PebbleTech
    • rebar #3 8" o.c.
    • 2" plumbing
    • vs-3050 pump
    • 420 catridge filter
    • Pentair Legend Plat
    • 1x500w pool light
    upgrade 130' flagstone coping: 1,000
    upgrade to 3 LED light: 2,000
    Upgrade to easy touch 8 control: 1,900
    Exta 110' gas line to heater: 1,100
    Extra 300' electrical run: 1,300
    Extra steel/Gunite for wall facing lake: 2,000
    Extra for deep end ramp+bobcat: 1,200
    Soil testing+engineering: 3,000
    drainage: 8 heads + 150ft 4": 1,500
    New 790 deck w/ stamped concrete: 7900
    470 stamped concrete on existing concrete: 4700
    70' stamped concrete steps: 1,400
    Extra deck beams 115' due to slope yard: 2,300
    Extra exterior tile 100sqft: 2,400
    Extra exterior stamped coat 100sqft:1,000
    7' Spa w/400k btu heater/100w LED: 7,000
    36' negative edege w/1.5hp pump: 10,000
    20' raised beam (12") w/tile: 1,000
    5 ton waterfall w/2hp pump: 7,500
    Total: $99,000
    2nd bid:
    Pretty much similar to above but no detail pricing with following differences:
    610sqft (same 40'x21')
    DE 60 sqft plus filter
    3x2.5hp whisperflo for pool, waterfall and negative edging
    2x500w amerilite
    3x100w for spa, waterfall, basin
    8 ton moss rock (2 waterfalls)
    900sqft new stamped concrete
    50' flagstone deck steps
    Flagstone facing on wall facing lake instead of tile
    no mention of soil testing/engineering
    Total: $90,000
    Any suggestions/opinions will be greatly appreciated.
    Inground SWP, 10,000 gals., year installed 2011
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: Pool bids in Houston
    Welcome...
    Without going through my quotes in detail, the one thing that stands out is the high cost for the stamped concrete ($10 per sq ft). I'm from the land of fruits & nuts (CA), and even here I'm only paying $7.00 per sq. ft. for a stamped and colored concrete with multiple pattern choices.
    Otherwise.. good luck.. that pool is HUGE!!!
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Apr 2012
    Klein Tejas
    249
    Lake Houston?
    There is thread here about another Lake Houston build.
    Every extra in your bid is priced at a premium. I'm frugal, I'd keep looking.
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
