Results 1 to 14 of 14
Thread: Are my motors dead?
    Are my motors dead?
    I've got a Hayward RS2000 pump for the pool and a Polaris Booster Pump. I had electrical issues that my buddy was able to help me track down to a horribly wired electrical box that has a bad short. We bypassed everything in the electric box only leaving the pumps on the line for power. I thought my two timer boxes were broken due to the previous short, so without even testing the motors by bypassing the timers I bought new timers. Got them installed and both motors will not turn on. I've verified I'm getting power all the way to the motors, but don't know if I've killed the motors or if there is some sort of fuse within the motors. Both motors are wired for 240 volts. I can't find a fuse on either of them and fear I'm going to have to purchase new ones. Any help would be greatly appreciated.
    22,549
    Re: Are my motors dead?
    do the motors make any sounds when trying to start? Like a hum?
    There are no fuses per-se in the motor. There are thermal cut-outs but they're self resetting so that's not the problem. Are you familiar with using an ohm meter? If so then you should be able to check the windings for an open.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Also depending on the motor there may be a 120V/240V switch. Pictures?
    Bama Rambler
    I do not hear a hum, but I also haven't gotten real close to check for that. I'll check that in the morning. I have an ohm meter, but sadly I don't know how to use it. I'll ask my buddy to show how to use it.
    bobodaclown
    I believe one or both of the motors has a 120V/240V switch, but unless the short flipped that, they should still be set to 240V.
    I was mainly posting to find out if there is a fuse I couldn't find on the motors. My hope is that I was/am missing something because both motors are not working. I would feel more confident that one motor is dead if one of the two would worked. Can take pictures in the morning if you think it would help.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by toph
    Bama Rambler
    [youtube:22l9jktp]bF3OyQ3HwfU[/youtube:22l9jktp]
    EDIT - I looked at those first youtube's I posted - they sucked.
    Try this new one.
    Jun 2012
    Mint Hill, NC
    2,589
    IF the motor was humming loudly this test/fix would be what would be the first recommendation:
    [youtube:3biynyq5]k-cVgpz7GYQ[/youtube:3biynyq5]
    May 2012
    Montville NJ
    545
    Quote Originally Posted by UnderWaterVanya
    Bama Rambler
    [youtube:3tsgt4di]bF3OyQ3HwfU[/youtube:3tsgt4di]
    Try this new one.
    That one is not bad, but I take umbrage with him discounting analog meters. I can kick an analog meter and tell you how many it is to an open in a wire. You are not going to be able to do that with a DMM. Same goes for any sort of fluctuating reading, analog will tell you a lot more. But yeah, for general purposes a DMM is just fine and that video is pretty good.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by phonedave
    -dave
    I agree - I have both types of meters and they each have their purpose. The general advice that most people should not buy an analog meter as their first choice is probably sound - but they aren't junk. In fact it is probably easier to test a capaciter for basic function using an analog meter...
    Big thank you for the help y'all. The videos are great and my buddy also gave me a quick tutorial. He's on the other side of my cube wall. I'll post my results.
    Jun 2012
    Mint Hill, NC
    2,589
    Happy to help.
    Well I've been putting off the troubleshooting of this motor problem. I finally pulled the capacitor and it looks like it works, see photo of silver capacitor and multimeter. I pulled the back off the motor and found another capacitor (black). It has three wires attached with a total of four possible connections. Not sure how I go about testing this one. I won't lie capacitors scare me. So, with that I really want advise before I go testing different connections on this capacitor with my multimeter.
    Jun 2012
    Mint Hill, NC
    2,589
    It looks to me like the two yellow wires attach to a single clip box tab type connector. First take the multimeter in continuity mode and check to see if the two yellow wires are connected - I think they are. Then test just like you did the first one - using the terminal with the white wire as one side and the terminal with the two yellow wires as the other side.
    That's all there is to it. Any precautions and draining you did on the silver one will be applicable to the black one. If you want to drain the cap more slowly get a large wattage resistor rather than a screw driver to tie the two sides of the capacitor together and drain the current out.
    Yep the yellow wires were attached to a single clip box tab. So I tested the capacitor and it looks like it is working. Is there any way I can test the motor or does this mean my motor is pretty much dead?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Could also be the contacts on the centrifugal switch. Try cleaning them.
    Mark
